Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-20-2005, 02:00 PM
Chris81579 is on a distinguished road
servos not activating
I have a Anilam conversational controll on a topwell milling machine and when I started it today. It was about to do its home sequence and it had a message too much lag on z axis and would shut off the servo. If I jog the machine it would kick off the x allso with the same message. Now the servos won't even turn on. The machine will move freely if moved manualy. I checked all the fuses that I could find and 1 was blown I replaced it and it still doesn't work. Does anyone have any ideas I was on the phone with Anilam and he told me it was a fuse but i can't find the culprit.
Old 03-11-2006, 02:09 PM
ts4tomh is on a distinguished road
Manually, you mean by handwheels, yes? Power supply output OK? If the servo power supply was not delivering, commands to servo amp would go unanswered, but fuses would still be intact, perhaps.
[IMG] code is Off
