Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-01-2012, 07:58 AM
luckydoglele's Avatar
luckydoglele is on a distinguished road
Need Help! Delta servo motor problem
i have a cnc router with four heads, each head has 3kw air cooled spindle. i use 1.5kw delta servo motor in x axis , and two 1.5kw delta servo motor in y axis. but now i have error in x axis, the code is ERROR 11. and i change a new one, after work a few days, it appear the same problem ERROR 11 again. so how to do now, anyone who can help me??
is that the power is not enough or other problems??
i have already connect the ground wire for each inverter.
[IMG] code is Off
problem with servo motor (video) DanOSB DIY-CNC Router Table Machines 17 08-13-2010 09:43 AM
Delta tau nc2.36 servo error JR1050 General CNC (Mill and Lathe) Control Software (NC) 9 09-02-2009 11:59 AM
Need Help!- i got a problem with Y axis servo motor. tarikk K2CNC 2 07-04-2009 10:36 AM
Need Help!- Servo Motor Shaft Problem Iron-Man Servo Motors and Drives 5 06-19-2009 05:20 PM
Servo motor problem after teardown? altered Servo Motors and Drives 18 04-22-2007 02:48 PM
