Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-11-2003, 12:20 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Grinding tool bits
It this enough to grind my own lathe bits?
http://www.harborfreight.com/cpi/cta...emnumber=34948
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-11-2003, 12:42 AM
HuFlungDung's Avatar
Moderator
Maybe! The wheels that come with it may not be exactly what you'd want, but that is easy to fix. It is actually maybe a little underpowered for an 8 inch grinder. Depends how hard you want to lean on it. 3/4hp is more common for an 8" grinder. It would sure be nice to examine the shaft size farther up from the wheels, to see if it is as beefy as a 3/4 hp unit. Otherwise, the thing will always seem to be buzzing because of shaft flexure due to slight out of balance.
Old 08-11-2003, 02:38 AM
Chagrin is on a distinguished road
You shouldn't need to push that hard on the grinder - those little bits get hot in a hurry and you should be more worried about pausing and dunking them in water to keep them cool. I use a 6" grinder and the only shortcomings I've found are with the junk toolrests found on all these types of grinders.
Homier has cheaper models, by the way (http://www.homier.com/itemdetail.asp?i=03009&c=11 - 8" 3/4HP for $20).
Old 08-15-2003, 10:06 PM
CNCadmin's Avatar
Site Owner
Thanks for the info I'm going with the 3/4 hp grinder.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
[IMG] code is Off
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 05:24 PM
Tool Grinding Literature Needs mc_n_g Toolgrinding & Toolgrinding Machines 11 04-03-2009 12:28 AM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Stop Bits, Parity gar Computers and Networking 4 06-04-2005 03:10 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
