Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 11-25-2011, 02:26 PM
stevewotherspoo is on a distinguished road
HITACHI SEIKI HT25 TURRET ERROR
Hello, Still scratching my head thinking about this turret error problem that has appeared and gone away over several days.
Turret error is now terminal with no turrent movement. Can manually move turret.
Check hydraulic pressure OK.
Checked solenoids, all ok.
Turret will not reset back into position and will now no turn.
Secondary problem is an intermittant video. Switchs on, works all day without problem. Turn it off and several attempts required to turn it on again.
Started pulling turret down and would muchly appreciate any advice.
Thank you
Steve Wotherspoon
Old 11-25-2011, 04:00 PM
Seili HT25S TURRET ERROR
Second problem seems to be a faulty connection and is fixed.
Problem still remains with zero rotation turret.
Tahnks
Steve
Tags
cnc, seiki, trailer axle
[IMG] code is Off
Turret problem after crash on Hitachi Seiki HT20-SII Driftwood General Metal Working Machines 6 02-02-2011 12:56 PM
Need Help!- hitachi seiki vm40 error 141 Mousie General CNC (Mill and Lathe) Control Software (NC) 0 10-15-2009 04:10 AM
Need Help!- HT20J Ye-Net I/O Error(Hitachi Seiki) ikklassen General Metal Working Machines 0 04-18-2009 02:35 PM
Hitachi Seiki with Yasnac LX-3 Error dannyboysd89 General CNC (Mill and Lathe) Control Software (NC) 7 08-08-2006 07:54 AM
Need help on Hitachi Seiki error 1012 anti-SAMS Machine Problems, Solutions , Wireless DNC, serial port 1 11-24-2004 07:26 PM
