Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-30-2011, 09:28 AM
jalal aw is on a distinguished road
mini cnc gv2518f
I bought a used Chinese mini cnc Hefei Liyu CNC Equipment CO.,LTD.¡ª¡ª Cutting plotter Mini engraver Engraver(CNC Router) Mould engraver Optional parts But no operation manual, driver software, and RS-232 cables, I bought a cable form a local store and contact the cnc to pc but no communication.
I emailed the Chinese manufacturer several time no answer
Any suggestion,
Thanks.
jalal aw
artncraft2010@hotmail.com
Old 08-30-2011, 04:39 PM
angelw is on a distinguished road
Any suggestion,
Thanks.
jalal aw
To establish communication between two devices, two things need to be satisfied.
1. The cable has to be the correct pin out configuration for the hand shaking method set at the control and the PC.
2. The setting at the control and PC have to be compatible with each other and the cable.
What type of control does the machine have? You will probably need to get a list of the parameters for the machine so that the setting for the communication can be set, or at least know what the settings are so that the PC software can be set accordingly.
Regards,
Bill
[IMG] code is Off
best way to cut stock for machining on mini lathe/mini mill crazybrit Benchtop Machines 37 12-31-2011 03:40 AM
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
Stepper Control for a Sherline Mini (real mini) bill south General Metal Working Machines 2 07-05-2007 11:04 PM
mini v-4 rcmachinist I.C. Engines 3 06-02-2007 01:38 AM
