Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-17-2011, 10:57 AM
hammy is on a distinguished road
trumpf 200 Nibbler problem
problem with a trumpf 200 nibbler and bosch controller ...machine started to punch hard with the multi tool leaving embossments ...replaced controller software and it fixed the problem for a short while ...if the first sheet was run (subsequently damaging it) then the second sheet would run fine...this is with .063 and higher AL ...tried go block to the last line that featured m25...punch code ...load sheet and then it was fine for a while now that is not working out ..any suggestions ...would extra memory help anyone else have this problem ....thanks in advance Hammy
[IMG] code is Off
Newbie- CNC nibbler very thin sheet metal kalpsin78 Want To Buy...Need help! 0 07-08-2011 12:30 AM
Need Help!- Problem with our Trumpf TC 200 nickampm Machine Problems, Solutions , Wireless DNC, serial port 1 11-15-2010 11:32 AM
Shears vs Nibbler...This question is so basic Im ashamed! diarmaid General Metalwork Discussion 18 09-09-2010 04:15 AM
Trumpf tc120R caredas G-Code Programing 3 08-17-2009 02:10 PM
trumpf bosch cjerickson Post Processor Files 0 07-29-2005 07:54 AM
