Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-06-2011, 09:04 AM
kccement is on a distinguished road
Exclamation Fanuc power input unit (A16B-16000090/05B) ALM LED (RED)
Dear all
Please help me to fix the problem in my cnc machine.
When switching on machine is not power up. I found the ALM LED (red color) of the input power unit (A16B-1600-0097/05B) is turning on after 2 sec of switching on machine of course green LED is continuously glowing.
Even if i switch on by removing CP2 connector which is going to Main power supply of system chassis still same is happening.
Kindly help me to solve this problem to keep running my machine.
regards
KNR
Old 08-20-2011, 05:18 AM
GOOD.4286 is on a distinguished road
Originally Posted by kccement View Post
Dear all
regards
KNR
there may be short circuiting to the connected terminals. if it is not so then find the main phase supply.is it ok then open the unit. check the regulating section by testing it on test points. however there is another forum on which you can post your query and they may help you
CNC FORUM | All About Technology
[IMG] code is Off
RECONDITIONED FANUC POWER SUPPLY ( A16B-1212-0110-01 ) CNCadmin EBAY ADS 0 07-22-2011 03:00 PM
Fanuc 10TF alarm on input unit emexcee380 Fanuc 1 06-08-2011 07:29 PM
FANUC Input Unit gbowne1 Fanuc 0 04-11-2010 07:23 PM
Schematic for Fanuc A16B-1211-0890-01 Power Unit celsosc Fanuc 0 11-14-2008 06:02 AM
Fanuc power unit problem sbp Fanuc 3 03-25-2007 09:08 AM
