| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| This problem I got when I was trying to do program transfer in Siemens 820D, The transfer was working without any failure but when I checked the program, i could find some extra characters at the beginning (received program is attached with this thread) Is there something I need to do with machine controller?? or is it some thing to do with my cable/ connectors?? Please anyone guide me onthis. Thank you............ |
I have an Hit 8s when I transfer the program to my computer I get the same added character but strip them out before I transfer back to the machine. You need the %MPF at the beginning as in my sample. Hope this helps. BTW I use bobcad for transfers. Gene %MPF20 N10 G54 D4T4 ( 6_5NRSFT ) N15 G00 G90 G70 Z0.0 N20 X.675 N25 G01 X0.0 S500 M3 M8 F.003 ( FACE ) N30 G00 X3 Z3 N35 G54 D5T5 N40 G00 G90 G70 X0.0 N45 Z.05 N50 G01 Z-.170 F.002 ( CENTER DRILL ) N55 G00 Z3 N60 X3 N65 G54 D1T1 N70 G00 G90 G70 Z-1.072 N75 X.7 N80 G01 X.625 Z-1.080 F.003 N85 G02 X.625 Z-1.176 I.000 K-.048 N90 G00 X.7 N95 Z.05 N100 X.590 S530 M3 M8 F.0045 ( TURN O.D. ) N105 G01 Z-.635 N110 G00 X.635 N115 Z.05 N125 X.540 N125 G01 Z-.635 S560 N130 X.625 N135 G00 Z.05 N140 X.480 N145 G01 Z-.635 S590 N150 X.62 N155 G00 Z.05 N160 X.420 N165 G01 Z-.500 S620 N170 X.588 N175 G00 Z.05 N180 X.400 N185 G01 Z-.500 N190 X.62 N195 G00 Z.05 N200 X.280 N205 G01 Z0.0 N210 G01 X.367 Z-.06 F.002 N215 Z-.420 (UNDER CUT THREAD RELIEF N220 X.320 N225 G01 Z-.500 N230 X.65 N235 G00 X3 Z3 N240 G54 D2T2 ( 3/8-16 THREAD ) N245 G00 G90 G70 Z.05 N250 X.65 S300 M3 M8 d K99 ( Thread cutting external ) ( R20 = Thread pitch R21 = Start X ) ( R22 = Start Z R23 = Idle passes ) ( R24 = Thread depth R25 = Finish allowance ) ( R26 = Run in R27 = Run out ) ( R28 = Rough cuts R29 = Infeed angle ) ( R31 = End X R32 = End Z ) N99 R20=0.0625 R21=0.375 R22=0 R23=2 R24=-0.048 R25=0.003 R26=0.05 R27=0.01 R28=8 R29=0 R31=0.375 R32=-0.500 L97 P1 N255 G00 X3 S500 N260 Z3 N265 G54 D1T1 N270 G00 G90 G70 Z.05 N275 X.280 N28 G01 Z0.0 N285 G01 X.367 Z-.06 F.002 N290 Z-.420 (UNDER CUT THREAD RELIEF N295 X.320 N300 G01 Z-.500 N305 X.420 N310 G03 X.480 Z-.530 I0.0 K-.03 N315 G01 Z-.630 N320 X.565 N325 G03 X.625 Z-.660 I0.0 K-.030 N330 G00 X3 Z3 N335 G54 D2T2 ( 3/8-16 THREAD ) N340 G00 G90 G70 Z.05 N345 X.65 S300 M3 M8 d K99 ( Thread cutting external ) ( R20 = Thread pitch R21 = Start X ) ( R22 = Start Z R23 = Idle passes ) ( R24 = Thread depth R25 = Finish allowance ) ( R26 = Run in R27 = Run out ) ( R28 = Rough cuts R29 = Infeed angle ) ( R31 = End X R32 = End Z ) N99 R20=0.0625 R21=0.375 R22=0 R23=2 R24=-0.048 R25=0.003 R26=0.05 R27=0.01 R28=8 R29=0 R31=0.375 R32=-0.500 L97 P1 N350 G00 X3 N355 Z3 M5 M9 N360 M0 ( FLIP PART ) N365 G54 D4T4 N370 G00 G90 G70 Z-.019 ( FACE TO LENGTH ) N375 X.7 N380 G01 X0.0 S500 M3 M8 F.004 N385 G00 Z3 X3 N390 G54 D5T5 N395 G00 G90 G70 X0 N400 Z.050 N405 G01 Z-.195 F.002 ( CENTER DRILL ) N410 G00 Z3 N415 X3 N420 G54 D1T1 N425 G00 G90 G70 Z.025 N430 X.590 S530 M3 M8 F.0045 ( TURN .437 O.D. ) N435 G01 Z-.770 N440 G00 X.635 N445 Z.025 N450 X.540 N455 G01 Z-.770 S560 N460 X.625 N465 G00 Z.025 N470 X.457 N475 G01 Z-.770 N480 X.625 N485 G00 Z.025 N490 X.377 N495 G01 Z-.019 N500 G03 X.437 Z-.049 I0.0 K-.03 N505 G01 Z-.770 S590 N510 X.565 N515 G03 X.625 Z-.800 I0.0 K-.03 N520 G00 X2 Z3 N525 G54 D3T3 ( PUT IN GROOVE ) N530 G00 G90 G70 Z-.060 N535 X.5 N540 G01 X.340 F.002 N545 G00 X3 N550 Z3 M5 M9 N555 M2 M02 |
| I have posted the same in the Siemens forum and next day In got the answer and the answer was "Set Punch tape format in PC as well as CNC. Then you will get the exact program with out extra characters.The setting in CNC you can find in Press Shift key hold it & press Alarm key the Press Data I/O --> Settings. here you can change it" |
| Newbie- EXTRA SPACES WHEN KICKING PROGRAM ONTO COMPACT FLASH? | jay_dizzle | Fanuc | 6 | 09-03-2010 04:29 PM |
| shift Z-zero inside mazatrol program | kendo | Mazak, Mitsubishi, Mazatrol | 1 | 05-22-2010 08:21 AM |
| Problem- Pay extra for dongle, or else! | hecirp | BobCad-Cam | 3 | 12-29-2009 07:59 PM |
| I have not recieved a email to complete the registration | CNCadmin | CNCzone.com FAQ | 0 | 02-16-2007 10:16 AM |
| I finally recieved my new machine. | trilect | Smithy | 8 | 06-08-2005 02:53 PM |
