Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-27-2011, 08:19 AM
PBr PBr is offline
PBr is on a distinguished road
Mori Seiki JR + fanuc10M
Hi everybody,
Me and a friend of mine have bought this machine recently, but we've got stuck setting it up. The baterries went off, so we started to set the OP parameters in IPL menu (16 of them - is there any description what they mean?).
After it we've managed to upload the parameters from PC. Also the timers/counters/keeprelays were OK, but we couldn't set the datatables correctly. We could set the data control (first screen), but following the instructions in the manual for mori we should be able to "enter" each data table by pressing the "Data" soft key again. This doesn't happen. What could be wrong?
Also is there any document describing the parameters of fanuc?
Also could someone look up the correct data who's got the same machine? It's MV-JR, year 1985.
thank you.
[IMG] code is Off
Problem- Did Mori Seiki Buy Hitachi Seiki? Billet Sean Mori lathes 6 05-04-2011 10:12 PM
Mori Seiki Sv-503 mr-seiki Servo Motors and Drives 2 06-03-2010 08:52 PM
mori seiki #'s chunkymonkey Parametric Programing 1 10-30-2009 11:34 AM
Mori Seiki SL1 LocTite98 Mori lathes 1 03-25-2008 06:40 AM
mori seiki? manuelc149 General Metal Working Machines 10 10-24-2007 06:15 PM
