Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-23-2011, 04:41 PM
Marcin81 is on a distinguished road
Slow motion and harsh noise
Hi to all,
I need some help with setting up my mach3 configuration. I read almost every post that I could find on the internet but still can figure it out what's going on. The problem is that when I jog the machine it moves smooth and fast but when I load g code for profiling the motion slows down and motors makes a lot of harsh noise. I tried different motor tuning configuration and also many other settings but no luck at all. Some specifications of my setup:
PC:
Processor: Pentium 4 - 3.2Ghz
Ram memory: 2 Gb DDR2
Cnc
Controller: Tb6560 board
X axis: Nema 34 step motor, 8 micro steps, 16mm screw, pitch 10 mm
Y axis: Nema 23 step motor, 8 micro steps, 16mm screw, pitch 10 mm
Z axis: Nema 23 step motor, 8 micro steps, 16mm screw, pitch 5 mm
Here you is the link to short video where you can see and hear what's going on with the machine when jog and when start working on the profile cut.
YouTube - ‪cnc‬‏I also made screen shots of my mach3 configuration.
ID:	134770   Click image for larger version
ID:	134771   Click image for larger version
ID:	134772   Click image for larger version
Old 05-23-2011, 05:20 PM
ger21's Avatar
Sounds like resonance. Try jogging at slower at different speeds, especially slower, and see if it does it then. If so, it's probably resonance. If you have dual shaft motors, try making some dampers.
http://www.cnczone.com/forums/steppe...tml#post256639
Old 05-23-2011, 06:23 PM
Hi Gerry,
Thank you for the replay. The machine acting like this in every speed. Every time when I import g-code with with curved or 3d profile it is this same.
Thanks,
Marcin
[IMG] code is Off
BST LINEAR MOTION-Professional Manufacturer for Linear Motion Products In China bstlinearmotion Product Announcements & Manufacturer News 0 11-06-2010 01:15 AM
OKK VM5 slow ATC kwmkoester Mazak, Mitsubishi, Mazatrol 3 11-02-2009 11:36 AM
Slow TL-1 Edster Haas Mills 2 04-05-2006 02:56 PM
Slow Jog Don C Yeager Automation 6 06-02-2004 12:34 PM
