Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-13-2011, 09:35 PM
nak1411 is on a distinguished road
Exclamation Amada III 357v Problem
The machine that I work with(Amada III 357V punch/laser) is encountering many strange problems. I will list a few. Occasionally I will be unable to zero reference the table/turret/laser at all. The axis lights will be out and the buttons seem to be unresponsive. I have somehow managed to get it to reference by punching all the reset buttons at random and flipping tool change on/off. When it finally references and i am ready to start a program, the tablew will move to the starting position and just sit there without punching or cutting. Sometimes it sits there indefinately, sometimes it starts right away, and other times it will just sit there for minutes on end before starting. It does the same thing for the laser. It will sit in position, red laser cutting light will come on, but the laser will not go down and start. Worst case is the WHOLE NCT will freeze up(laser wont even power down) and is totally unresponsive causing me to have to trip the main breakers.
there are no programming errors(these programs have been run before flawlessly)......bottom line, this seems to be an electrical issue but I cannot pin-point it..bad boards? overheating issue? and yes i have been trying to diagnose this for a couple days so its not a simple "is there a stop button pushed in?" solution.
thank you
Old 05-17-2011, 10:47 PM
still no luck, I found that flipping the tool change switch on and off will allow it to continue very temporarily. It seems to get worse as far as the frequency of stoppages the longer it runs, almost seems like a heat or pressure problem.
Old 11-22-2011, 07:06 AM
ryboy2222 is on a distinguished road
Did you ever figure this out? It sounds like the first thing you need to do, is try to reference each axis one by one. See which one wont reference first.
Tags
amada, freeze, laser, problem, punch
[IMG] code is Off
PROBLEM WITH FANUC 6M on Amada Coma cristalex_it_sr Fanuc 13 12-01-2011 03:35 PM
Need Help!- Amada 357 Independent CNC Fanuc 8 07-18-2011 01:13 AM
Amada Pega 345 X axis parallelism problem terrycoughlan CNCzone Site News and Contests 2 06-08-2011 04:22 PM
Amada Press Brake Controller problem jamesbond007 Bending, Forging,Extrusion... 3 10-17-2009 03:49 PM
Amada Fanuc 0L problem laser rick_7037 Fanuc 7 12-16-2006 02:48 PM
