Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-05-2011, 09:41 PM
agung_atmi36 is on a distinguished road
Turn Off Dry Run with M code or G code
Let me Introduce my self, I am Agung and i worked as an engineer in autocomp manufacture. I want to know, is there any M or G code which can turn off dry run mode, while run the machine ?
Old 05-05-2011, 10:47 PM
broby's Avatar
broby is on a distinguished road
Short answer... NOPE!
Old 05-06-2011, 04:48 AM
Superman's Avatar
Superman is on a distinguished road
Well....... in a way, you might get around it
If you could find the input logica,l or similar, and to be able to read if a certain switch is ON, then direct it to the action that you want it to do
ie
IF ([switch code) = 1] , message " SWITCH XXX is ON", M00
but this depends upon the machine control and it's options
Old 05-06-2011, 08:14 AM
broby's Avatar
ie
The only logical action you would want to take is to direct the program to either program stop or generate an alarm.
Any other action would/could result in serious problems, imagine trying to drill a hole with the machine running in dry run mode and the dry run speed set high, or with the speed set to zero, then nothing would get done.
Hmmmmmmm
[IMG] code is Off
Newbie- Takeout Unused G Code commands in Mastercams Generated G Code shneek Mastercam 8 12-15-2010 02:32 PM
Newbie-> Using G Code to turn a relay on Delanoman G-Code Programing 4 08-29-2009 11:33 PM
Need Help!- G-Code to turn on and off router, non-spindle Sam A G-Code Programing 6 10-24-2008 08:02 PM
G-code manual for Mach3 turn? Green0 Mach Lathe 4 06-25-2007 07:57 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
