Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-04-2011, 09:17 AM
Clyde_06 is on a distinguished road
Setting up DNC for the first time
Hello, i'm trying to set up a DNC here at our shop. We just built a new computer and we had 2 25 pin RS-232 ports put in through the PCI slots. I downloaded extreme DNC (thats what we used at my old job so it was what i was used to). the only problem is when i try to set up my Haas VF2 it won't do anything. when i try and choose the port it gives me Com1 and Com2. my computer says they're in PCI slots 3 and 4 (PCI Slot 4 (PCI bus 3, device 4, function 0)). how do i get to work? is there a difference between a 25 pin serial cable and a 25 pin rs-232 cable?
Old 05-04-2011, 06:19 PM
dcoupar's Avatar
The "serial" ports (RS-232) should be assigned a COM number. If your PC doesn't have a standard DB9 com port, then the 25 pin ports should be COM1 and COM2. Set your DNC software to use either COM1 or COM2.
Haas only needs 3 wires to send/receive RS232. Your cable might look like this:
CNC <-------------------> PC
1 <------ shield------ no connection to PC
2 <----------------------> 3
3 <----------------------> 2
7 <----------------------> 7
You can't use a straight-thru cable because pins 2 and 3 don't cross. If you have straight-thru cables, I believe you can use them if you get a couple of Null-Modem adapters from Frys or Radio Shack.
Old 05-04-2011, 08:26 PM
tommyo is on a distinguished road
RS232 signal meanings
OK
9 pin or 25 pin the signals mean the same:
older 25 pin
pin1 (shield ground) helps aviod noise suggest grounding only
one end of long cables to aviod ground loops
pin 2 TX (talk)
pin 3 RX (listen)
pin 4 RTS (do you mind if we talk)
pin 5 CTS (I'm ready to listen)
pin 6 DSR (this end has something on)
pin 7 signal ground (completes reference circuit)
pin 8 DCD (says the modem has tone)
pin 20 DTR (says the other end has a device on it)
Simplest connection requires:
signal ground connected to both devices 7-7
TX talk to RX listen 2-3
RX listen to TX talk 3-2
jumper CTS and RTS together 4&5
jumper DSR, DTR and DCD together 6&20&8
If you connect RTS to CTS together on each end of the
cable without going through the cable each device lies
to it's self. This used for "hardware handshake" to
pause transmission in large files. Some software use
"software handshake" Xon Xoff or DC codes. (It's
actually control S control Q if typed on a keyboard
to test it)
If you connect DSR to DTR together on each end of the
cable without going through the cable both ends always
think something is there.
Sometimes computers need to believe a modem exists
before software will work. DCD needs to be tied high to
lie for the software. Easiest way is to jumper it to DSR
because it must be there if you are using it.
9 pin connections do not have shield ground. For some
unknown reason they could not even keep TX and RX
signals on the same pins?
Start with a short file. 2400 baud, 7 data bits, even parity
Good Luck
Tom OConnor
Tags
dnc haas vf2 extremednc
[IMG] code is Off
Need Help!- Setting time of day on VF1 dave design Haas Mills 4 11-29-2010 12:57 PM
Need Help!- Question about the accuracy and setting changes for cycle time estimates in backplot CJH Mastercam 2 08-01-2010 06:02 PM
Need Help!- long time reader first time poster blu333 General Metalwork Discussion 0 02-21-2010 05:30 AM
Need Help!- Setting up 4th axis for the 1st time... jmcglynn Haas Mills 5 06-11-2009 09:02 PM
cnc time setting subshri General CNC (Mill and Lathe) Control Software (NC) 2 05-27-2009 12:31 AM
