| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
I am running stepper motors from the KL-8056D unit with the KL- 6520 (65volt) power supply controlled through a C35 - QUICK SETUP BREAKOUT BOARD running off of a SmoothStepper USB Motion Control Interface for Mach 3 running Mach3 software. When the motor (1350oz) has a load on it, it runs fine, BUT without a load on the motor it will not. Sometimes it turns and sometimes it freezes (whirrs). It cannot be tuned, it does this at all settings. Even with a light load I have this issue. I have also tried a 820oz motor and it does the same thing. This motor is turning a 60 inch ACME screw horizontally with a 40 lb load on the screw and fails to turn as described above. It works fine with a set up where it turns two 60 inch screws with a 140lb load Do you have any idea what is going on with this issue? |
| Need help with load calculation | SatanKlawz | DIY-CNC Router Table Machines | 5 | 01-25-2010 09:06 PM |
| Problem using stepper for high-momentum load... (blowing drivers!) | Riceburner98 | Stepper Motors and Drives | 10 | 09-17-2008 12:29 PM |
| Z load on vf-3 | mls | Haas Mills | 5 | 05-15-2008 10:54 PM |
| Stepper Motor Belt Drive Side Load Question | harryn | Stepper Motors and Drives | 3 | 08-07-2007 05:23 PM |
| stepper motor load resistor and figuring out phases? | drtuto | General Electronics Discussion | 7 | 03-19-2005 02:53 PM |
