Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-02-2011, 06:32 PM
enlightage is on a distinguished road
Setting up Magnum Phoenix Gs-512 CNC Router
Magnum Phoenix Gs-512 XHD CAD/CAM CNC Router.
It has a (2) head capacity, but currently only (1) is attached.(Perske 7hp? )
Looking for an estimate to execute the complete set up and integration of the new CamSoft hardware and software controller with the Phoenix CNC Flat Bed Router. The system was up and running for a short while before the old Controller CPU died and we were unable find a replacement due to compatibility issues because both the software and hardware were so outdated.
I believe we have all the components necessary to get the system up and running, but at this point, it is getting everything wired up and configured that we need help on.
Tags
cad/cam, cnc router., gs-512 xhd, magnum, phoenix
[IMG] code is Off
Need Help!- Magnum Phoenix GS CNC router jeffmorris Commercial CNC Wood Routers 10 05-01-2012 11:33 AM
Pheonix Magnum Cnc Router GEOFF Mechanical Calculations/Engineering Design 5 07-12-2010 05:21 PM
1995 Phoenix router moxbig72 CNCzone Club House 0 05-25-2010 01:02 PM
Need Help!- Phoenix Router / engraver beamsjr Wood Lathes / Mills 2 05-29-2009 10:16 AM
Pheonix magnum router GEOFF Commercial CNC Wood Routers 5 07-14-2008 03:40 PM
