Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-10-2011, 01:59 PM
pabrier is on a distinguished road
Unhappy Hermle UWF900E Simodrive fault
I have a Hermle UWF900E that keeps stopping, showing Emergency Stop error on screen. On checking inside the cabinet the Siemens Simodrive controller for the spindle drive motor shows a F14 fault (Exciter current monitor, actual less than or equal to 50% of set).
I have replaced the controller with a reconditioned unit, which gives the same fault. I have had the spindle drive motor with a motor repair company who found no problem with the motor or the tacho. I have had an electrician on site for the best part of a week changing relays like they're going out of fashion.
The Hermle service agent is not very local and wants stupid money to come over to check it out, and isn't very forth coming with info on the phone.
Any light anyone can throw on this would be appreciated.
Old 06-25-2011, 11:12 PM
dylancw is on a distinguished road
Just a thought, can you make up a separate cable outside of the housing to connect the drive to the motor, and test it that way? It could be a damaged cable...
Tags
f14, fault, hermle, siemens, simodrive
[IMG] code is Off
Need Help!- Simodrive 610 fault JSaindon Servo Motors and Drives 7 06-30-2010 08:15 AM
Need Help!- simodrive 610 Roberto1759 Servo Motors and Drives 0 02-10-2010 04:06 PM
810 M on a Hermle 721 cygnetron Siemens Sinumerik CNC controls 0 01-24-2010 11:44 AM
simodrive 611 mixalisxat Servo Motors and Drives 2 04-02-2008 01:37 AM
Hermle UWF700 ariesdenmark General Metalwork Discussion 0 11-22-2007 05:50 AM
