Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 07-23-2005, 12:05 AM
actmach is on a distinguished road
Question fanuc ot-c alarm 950 fuse break
Fanuc OT-C alarm 950 fuse break
Can anyone help ?
we have a wncl 20 femco with fanuc otc controler we are getting alarm 950 fuse break fx +24E
I looked in the fanuc O series maintenance manual it dosen't say much other than to replace fuse in power supply i wish it was that easy all fuses are good. when we flip on the main breaker at the machine the hydralic pump comes on fans work spindal board lights up everthing normal turn on at controller screen blank for about 15 sec. hear some relays come on then controler locks with alarm 950.
Power supply and mb both have green lights on i have even replaced P S with no luck, have even called femco and fanuc not much help there dose anyone have any suggestions? ANYTHING
THANKS ACTMACH@NETZERO.NET
[IMG] code is Off
