Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-09-2011, 05:39 AM
Ashish B's Avatar
Ashish B is on a distinguished road
SPACE buffering in DNC Unit
I was wandering that how DNC Unit Interprets a NC program with SPACE characters.
For Example -
N1 G90 G54 G90 G17
N2 M03 S500
N3 G00 X40.0 Y40.0 Z20.0
N4 G01 Z-2.0 F500
N5X52.075Y-103.576
N6X50.063Y-103.019
N7X49.843Y-102.854
N8X47.612Y-101.915
N9X45.380 Y-100.739
N10X44.404Y-100.050
N11G0Z39.014
N12 G1X44.019Y-115.923F9900
N13G0Z37.014
N14G1Z35.717F500
N15X44.513Y-116.306F3000
N16X48.296Y-114.177
N17 X49.843Y-113.585
N18X54.306Y-112.398
N19X58.770 Y-112.104
N20X63.233Y-112.579
N21X65.464Y-113.216
N22X67.696 Y-113.958
N23X69.927Y-114.982
N24 M05
N25 M30
IS IT POSSIBLE FOR A DNC TO INTERPRET THE Above mentioned program correctly ?
Ashish
Old 01-09-2011, 07:57 AM
dcoupar's Avatar
What is a DNC unit?
If you mean a CNC control I believe a Fanuc will "interpret" the program correctly.
Old 01-11-2011, 12:07 AM
Ashish B's Avatar
Thanks for your reply.
Older systems (Like 6M Control) don't have sufficient memory to interpret BIGGER SIZED Programs. It may be a NC Program created from a CAM software.
So, DNC Unit works as a OBJECT to read the Huge NC programs from personal computer, buffer it properly & then pass it on to the MACHINE CONTROL.
Machine control executes the program accordingly.
I hope that I was not too confusing.
Ashish
Old 01-11-2011, 08:05 AM
dcoupar's Avatar
I know what DNC is, I've just never heard it referred to as a "DNC unit".
Old 01-11-2011, 09:27 PM
Ashish B's Avatar
Any IDEAS on the problem mentioned by Me.
Ash
Old 01-11-2011, 10:44 PM
dcoupar's Avatar
Ash
What PROBLEM?
Old 01-14-2011, 07:28 AM
Ashish B's Avatar
I had the doubt that will the DNC Unit buffer properly a NC Program which has irregular spaces between the codes.
Ashish
Old 01-14-2011, 08:56 AM
dcoupar's Avatar
Ashish
According to the Fanuc 0M-C manual, spaces are ignored unless they are within a comment:
"If it is used in a statement other than a comment, the character will not be registered in memory. If used in a comment, it will be registered in memory."
Old 01-14-2011, 09:44 PM
Ashish B's Avatar
Thanks Dcoupar,
For that valueable information & insight on buffering pattern of a NC program.
Ashihs
[IMG] code is Off
Need Help!- FANUC 15-MA Battery unit & I/O unit etc gbowne1 Fanuc 0 05-04-2010 08:47 PM
suppressing buffering sinha_nsit Fanuc 5 09-03-2009 10:07 AM
Space in Frederick MD dgapilot Mentors & Apprentice Locator 0 02-25-2008 06:58 PM
Anyone else have space issues? cxixer DIY-CNC Router Table Machines 6 10-14-2007 10:37 PM
Paper space Model space ?? CNCadmin Autodesk Software (Autocad, Inventor etc) 10 05-29-2003 06:07 AM
