Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-05-2011, 07:18 AM
kinmo84 is on a distinguished road
Exclamation Spindle and tool changer problem
We have Johnford VMC-500 with Meldas M3. We have problem because battery broke down in our machine. Now there work all axis well, but spindle or tool changes doesn't work.
When tool change program stops there are two alarms ( SPINDLE ORI OFF LS CHECK and HI/LO GEAR LS CHECK ) and when try spindle there is only one larm ( SPINDLE OR OFF LS CHECK ).
Is here anyone who has same machine and can send us all programs what this machine use or can help us, we are creatfull.
Regards
[IMG] code is Off
Need Help!- 0ma tool changer problem curtistdc Fanuc 3 06-14-2010 06:20 PM
tool changer problem kling8 Mori Mills 2 02-25-2010 07:54 AM
Need Help!- Torq Cut 22 Tool Changer Problem MetalicGlow Bridgeport and Hardinge Mills 8 12-08-2009 07:41 PM
Mitsubishi 520 Tool Changer problem acrodave Mazak, Mitsubishi, Mazatrol 7 12-24-2008 07:58 AM
tool changer problem concordezz Haas Mills 10 08-20-2008 03:04 PM
