Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 07-16-2005, 05:55 PM
HansM is on a distinguished road
3.3 V vs. 5 V TTL on parallel ports
I've got my CNC router (the one Andrew built!) running off of a very old PC. I have a much newer one I would like to use, but when I tried it I got odd results running the machine. It would only move in 1 direction in all 3 axes. This happened with MDI, jogging, and running .nc files. I tested the voltage coming from the parallel port on the newer PC and it's 3.3 Volts. My controllers need 5V TTL so my guess is that's why I can't get it to change direction.
Is there any way to fix this other than buying a PCI parallel port expansion card in the hopes that it is 5 Volt TTL? Can anyone recommend a particular make/model of ppt expansion card that they know to be 5 Volt TTL? Or is there anything I can put in between the new ppt and toe controller to do a step-up DC-DC conversion?
Lance
Old 07-16-2005, 09:59 PM
ger21's Avatar
The PCI card is probably your only option. A post on Benny's Mach2 forum says this one is known to work. http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3666
Last edited by ger21; 07-17-2005 at 08:05 AM. Reason: I originally said auction instead of option.
Old 07-17-2005, 04:30 AM
jerber's Avatar
Gold Member
jerber is on a distinguished road
What you could try is to put a diode, like the 1n4001, between the ground of the controller and the ground of the parallel port. This should give a voltage drop of 1,2 volt and give you a voltage potential of 4,5 volt.
printer port ground _____________ diode______________controller ground
(I hope you can read my ascii schematic ).
____________________________________
Jeroen
Old 07-17-2005, 09:49 AM
Thanks for the replies! Gerry, that's just the info I need, I think I'll go that route. And the price is right too, CompUSA wants $30. for a ppt card!
Lance
Old 07-28-2005, 02:28 PM
Working!
Gerry,
I got a ppt card from the source you suggested and it works great! Now I can use the newer/faster PC to run my router! Thanks!
Lance
[IMG] code is Off
