Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-19-2010, 05:37 PM
Romper is on a distinguished road
Z axis problem
Hello everyone,
This is a strange one. Our z axis moves fine on large moves and jogs but when running a ski core profile (this is a piece of wood that is thicker in the middle and thinner towards the ends) it will not rise up to make the thicker part in the middle. The Gcode is correct. The motor vibrates and makes noise but does not move. The light for the z axis on the bladerunner box does not flash. The z axis does move down for each deeper pass but does not make its moves in the middle of the pass. The router accurately returns to zero after attempting to cut the profile so it is not losing position and is not mechanically jambed.
Thanks,
Morgan
[IMG] code is Off
problem with Z axis!!! Freddy Bastard Tormach PCNC 1 11-08-2010 11:20 AM
z axis Problem grahamshere DIY-CNC Router Table Machines 8 01-14-2009 05:19 PM
Need Help!- ref axis problem destro Machines running Mach Software 1 06-28-2008 11:25 AM
Problem- VMC Z Axis problem cam1 General Metal Working Machines 7 04-18-2008 04:11 PM
Problem with Z axis MagTDK DIY-CNC Router Table Machines 56 10-31-2006 08:12 PM
