Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-11-2010, 09:08 AM
Dirty Jerry is on a distinguished road
Smile Techno LC Series 4896 Tool problem!! Please help
Hi, we have a Techno LC Series 4896 CNC. I wasn't at the shop when the problem arose but for some reason it will not eject the tool that is currently in it. The air pressure is on and working fine but the machine will not allow you to manually remove the tool while holding the green button down. They tried resetting the fuse box completely last night while I was out of the shop but it changed nothing. Any suggestions would be very greatly appreciated! Thank you
Edit: The interface still seems to think the tool has dropped out because it asks you what tool is now in the machine, but it holds onto it like it never wants to let it go.
Edit: Problem solved!
[IMG] code is Off
Techno LC 4896 mechcanoer Techno CNC 7 05-18-2012 03:43 PM
LC 4896 Accuracy Problem ian12 Techno CNC 7 01-16-2010 10:40 AM
Techno Z Axis Motor Problem... Rick Turner Commercial CNC Wood Routers 4 12-17-2007 01:56 PM
BP series II Interact 4 tool release problem bherr Bridgeport and Hardinge Mills 2 08-05-2007 06:43 AM
Techno CNC LC Series Rotary layertone Commercial CNC Wood Routers 0 11-07-2005 11:52 PM
