Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 11-13-2010, 08:50 AM
nickampm's Avatar
nickampm is on a distinguished road
Angry Problem with our Trumpf TC 200
Problem with our Trumpf TC 200R,
I am having a problem with the head raising up all the way when we execute an m58 command while running a program. Head goes up all the way and shuts itself down????? Any Ideas? Trumpf has had us change out a couple of valves and stuff but we still have the problem. All ideas short of blowing the machine up are welcomed. Thanks
Old 11-15-2010, 11:32 AM
Independent CNC is on a distinguished road
Post
Why are you trying to use the M58? If you are trying to do this for formed parts I would suggest making any forms or embossed last or try to use the Sheet Type 2 in the M06 code.
Independent CNC Programmer
www.independentcnc.com
My mission is to share CNC programming innovations for a lifetime.
[IMG] code is Off
Trumpf Vectormark DIFF OVER Laser Engraving & Cutting Machines 1 09-09-2010 06:17 AM
Trumpf tc120R caredas G-Code Programing 3 08-17-2009 02:10 PM
You own a Trumpf L3050??? tikrik Laser Engraving & Cutting Machines 9 10-20-2008 02:05 PM
Metalsoft/trumpf Heftifab General Metal Working Machines 7 06-07-2008 08:07 PM
trumpf bosch cjerickson Post Processor Files 0 07-29-2005 07:54 AM
