| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Not sure if the problems are related but it seems so. We had a failure in the RS232 communications on this machine while sending some programs. The machine ust shut down while it was idle. Now when we reboot it we get an assortment of alarms. 329: PC CPU ERROR 327: UNFINISHED PROG GEN 310: SERVO OFF RESET 010: TH ERROR I was able to clear the 329 and the 010 with a #6014 D7 parameter edit. But now I still have 327: UNFINISHED PROG GEN 310: SERVO OFF RESET and have added 330: E STOP Servo off is normal until the second push of power on for this control. Any suggestions? John |
| 330 : E STOP 310 : SERVO OFF RESET 310 is normal. The 330 is only there when e stop is pressed. But now it won't go away with the switch in either position. John |
| John |
| If anyone else ever finds this in a search. Check the spindle chiller for alarms. Not sure if the problem started there but it ended there? John |
Because I have some issues with this machine recently acquire on eBay. Thanks Marco |
| These alarms look a lot like out of phase. Try just swapping two of the wires coming into the machine and fire it back up. John |
| Hi John I verify the phases and also did the same. Thanks anyway. Marco |
#10
| Hello Marco, We had a problem with E-stop when installed our Matsuura MC-760 MX3 machine. There is an electrical circuit connecting all parts of the machine that can break the circuit if there is a failure. (e.g. E-stop button on the panel, spindle oil cooling unit, e.t.c.). The last one was a cause of failure in our case, so we added some oil in the spindle and it solved the problem. I am not sure that the diagrams for 600 and 760 machines is alike, so you should find an electric diagram for your machine, find this circuit and follow it from start to end. Maybe you'll find at least what is causing the trouble. Igor
__________________ With kindest regards, Igor Kozlov |
| yasnac mx1 on matsuura programming help needed | Brian FRF | G-Code Programing | 29 | 01-15-2012 12:34 PM |
| G70, Yasnac Controller, on Matsuura | Brian FRF | General Metal Working Machines | 2 | 08-16-2010 12:12 PM |
| Matsuura Mill With yasnac controll, overload in x axis on rapid. | blakemachine | General CNC (Mill and Lathe) Control Software (NC) | 2 | 03-03-2010 07:45 PM |
| yasnac mx1 on matsuura programming help needed | Brian FRF | General Metal Working Machines | 0 | 08-04-2009 01:57 PM |
| Yasnac/Matsuura parameter specifying Z? HELP!! | arobustus | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-16-2008 02:28 PM |
