Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 10-14-2010, 01:54 PM
KCA324 is on a distinguished road
YASNAC I80 DNC-RS232 Troubles
On my Matsuura RA-3F I have a Yasnac I80 Controller. I seem to be able to send programs via "DNC Server" (iLogic) from my laptop. I am using a USB to 9pin I/O adapter. Then a proper 9pin-24pin Cable. In moderate sized programs I seem to be loosing information after sending it to the machine control. It will just be missing 20-40 lines. There doesn't seem to be any rhyme or reason for where its missing in the program, ie no unexceptable code or anything. The program I just tried was missing lines 282 up to 332, and 498 up to 516, and then again from 786-812.????
What could cause this??? Ive tried baud rate and other settings but nothing seems to change....
Any help would be great THANKS!
Old 01-09-2012, 11:56 PM
cncelect is on a distinguished road
What baud rate are you running?
Tags
communications, dnc, problems, rs232, yasnac
[IMG] code is Off
Yasnac i80, Rs232 problem dewcnc Machine Problems, Solutions , Wireless DNC, serial port 8 02-18-2011 12:03 AM
Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution? modernprecision Bridgeport and Hardinge Mills 1 09-11-2008 01:15 PM
Need Help!- Drip Feed to Yasnac LX3 vis RS232 Zig General CNC (Mill and Lathe) Control Software (NC) 2 07-20-2008 08:24 PM
air troubles wadetool Haas Mills 2 02-19-2007 03:30 PM
Fanuc 6T RS232 Troubles Bent82 Fanuc 6 02-06-2007 12:57 PM
