| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Hello all! I am a tech in Calgary who is troubleshooting an Aviator XLT plasma table with a Burny 1250 Plus controlling it. It goes through the boot up tests fine. It will load a program but when you start it there is an E-stop error. Also the machine will not Jog as the E-stop error is present. I have tested the E-stop circuit and the driver board is getting the 30dc + on the gray wire from the bridge rectifier when the button is in the normal run position. There is no external connection the the relay board e-stop input. Do you know of more tests I can run or perhaps a common reason the e-stop is halting the jog when the stop button is not pressed? It appears the gray 30vdc+ wire leaving bridge rectifier 2 (BR2) that is powered by the e-stop switch) powers the two fuses on the driver board. The power to those fuses goes on and off with the e-stop switch. So I don't think it has to do with that emergency switch directly. Thank you! Sheldon Last edited by Shredon; 08-31-2010 at 07:36 PM. |
| Burney 2.8 controller | Brainfarth | CNC Plasma and Waterjet Machines | 7 | 04-13-2010 08:06 AM |
| Need Help!- burney 3 | chris1230-5 | CNC Plasma and Waterjet Machines | 1 | 10-26-2009 08:53 AM |
| Just IN- New from AQE... GRINDMASTER 1250 Portable Downdraft Table 1250 CFM! | DaveG@AQE | Product Announcements & Manufacturer News | 0 | 03-30-2009 09:55 AM |
| Random Stopping - E-Stop Issue | EvanZ | DIY-CNC Router Table Machines | 6 | 11-07-2008 01:57 PM |
| THC on old Burney 5 table | carbidecraters | CNC Plasma and Waterjet Machines | 0 | 09-18-2008 01:23 AM |
