Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-29-2010, 09:53 AM
Fastest1 is on a distinguished road
Arc information not transferring or wrong?
Well you didnt think it would be long til I was back did you? The upload and downloads I have done have appeared to work. I have not checked every line for accuracy but I have checked just to make sure each line had content. I have a file that has the 4 different sized bores that creates a turners cube (271 lines). This file was created with BobCad and it worked well on my Sherline with Mach 3 and G code. I recomputed all of the toolpaths with the Dyna 2400 post processor and it writes a code that looks right as far as I can tell. When the code is run on the Dyna, I get 4 holes in a line and none are the right diameter however I do think the depth for each is right. It should plunge in the same place at 4 different depths and pocket/bore 4 different diameters. ? There was a statement in my manual that was hand written that says something about changing the O's to a Q's. This note was in reference to a software set up maybe as it was in the section on the ASCII codes and such. ?
[IMG] code is Off
Need help for cnc data Transferring VELLAIKANNAN General CNC (Mill and Lathe) Control Software (NC) 0 07-21-2009 08:12 AM
Transferring a Counter Value Adam Rehorn Fanuc 5 05-19-2009 07:41 AM
need help transferring cam chadillac General CNC (Mill and Lathe) Control Software (NC) 0 05-07-2009 01:45 PM
Need Help!- transferring dxf files to a hurco fritos HURCO 1 01-31-2008 09:48 PM
Transferring User settings HuFlungDung OneCNC 2 04-15-2003 10:05 AM
