Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-24-2010, 01:18 PM
Fastest1 is on a distinguished road
Predator receives, does not send?
I am using a cable configuration provided by Predator for a 9 pin to 25pin. It immediately allowed me to upload from my controller/machine to my xp computer, once I understood the process. However I can not seem to start a dowload. The machine is ready or claims to be and seems to never receive a signal from the pc. Upon opening the Predator send, it is already at 94%. Does it possibly need some form of start signal or key and if so how is it applied. I heard a % key was sometimes required at the beginning and end of the file. Upon uploading a demo file from the controller into my pc, I dont see any particular symbols.
Would the file help?
700 START INS 12
701 TD= 0.1250
702 FR XYZ =10.0
703 SETUP >zcxyu
704 GO X 0.5025
705 Y 2.0000
706 GO Z- 0.0400
707 GO Y 2.6750
708 GO X 0.6825
709 ZERO AT
710 X 0.6825
711 Y 2.4850
712 GR a- 90.000
713 GO Y- 0.2950
714 ZERO Y
715 GO a- 90.000
716 GO X- 0.1800
717 Z>C
718 >REF COODS
719 GO X 1.2250
720 GO Z- 0.0400
721 GO Y 2.3346
722 ZERO XY
723 GO r 0.3700
724 a 60.000
725 GO r 0.0000
726 GO r 0.3700
727 a 120.000
728 Z>C
729 >REF COODS
730 GO X 1.5825
731 Y 2.0000
732 GO Z- 0.0400
733 GO Y 2.6750
734 GO X 1.9525
735 Y 2.0000
736 GO Y 2.6750
737 Z>C
738 GO X 2.1225
739 Y 2.0000
740 GO Z- 0.0400
741 GO X 2.2400
742 Y 2.6750
743 GO X 2.3400
744 GO X 2.4517
745 Y 2.2250
746 GRcX- 0.2830
747 GO X 2.4975
748 Y 2.0000
749 CIRC iZ%050
750 XYCUT%070
751 ZH= 0.0000
752 Zd= 0.0400
753 XC= 1.5000
754 YC= 1.0000
755 r1= 0.7500
756 r2= 0.3500
757 CIRC oZ%050
758 XYCUT%070
759 ZH=- 0.0400
760 Zd= 0.0400
761 XC= 1.5000
762 YC= 1.0000
763 r1= 0.5500
764 r2= 0.3500
765 BOLT PECK=02
766 ZH=- 0.0800
767 Zd= 0.0200
768 XC= 1.5000
769 YC= 1.0000
770 a1= 45.000
771 N= 09
772 r= 0.4500
773 DRIL PECK=03
774 ZH= 0.0000
775 Zd= 0.0900
776 X= 0.3125
777 Y= 1.1875
778 REPEAT X 02
779 Xi= 0.2500
780 REPEAT Y 03
781 Yi= 0.2500
782 X= 2.4375
783 Y= 1.1825
784 REPEAT X 02
785 Xi= 0.2500
786 REPEAT Y 03
787 Yi= 0.2500
788 MILL iZ%018
789 ZH= 0.0000
790 Zd= 0.0500
791 X1= 0.0625
792 Y1= 0.5625
793 X2= 0.5625
794 Y2= 0.0625
795 X1= 0.0625
796 Y1= 0.8125
797 X2= 0.8125
798 Y2= 0.0625
799 X1= 2.9325
800 Y1= 0.8125
801 X2= 2.1875
802 Y2= 0.0625
803 X1= 2.9375
804 Y1= 0.5625
805 X2= 2.4375
806 Y2= 0.0625
807 FRAM iZ%030
808 ZH= 0.0000
809 Zd= 0.0800
810 X1= 0.0000
811 Y1= 0.0000
812 XA= 3.0000
813 YB= 3.0000
814 END
Old 08-24-2010, 04:40 PM
dcoupar's Avatar
How are your DNC Properties set?
Name:	Predator Editor DNC Properties.jpg‎
Old 08-24-2010, 06:20 PM
These are the settings as per the manufacturer, though they want to sell me some software. I did use the dnc wizard from the DNC4U program and it shows stop bits to be 2. I have tried it both ways with no difference. Uploads are fine, all parts seem to be correct. I did take my port tester and plug it into the machine only. Looking at the DB25 connector itself within the machine, only wires 2,3,4,5 & 7 are even physically connected. When powered up led's 2 (green) and 4(red) are on all else are off. I see no change in the led's no matter if I am going thru an upload or download sequence. Of course I am only doing this without a cable connected thru just to see if it would light any of the other leds as a signal to send or receive.
Old 08-24-2010, 06:31 PM
dcoupar's Avatar
How are the Predator DNC Properties set? Which boxes are checked?
Old 08-24-2010, 06:32 PM
If I jump pin 4 to pin 5 (still with only the port tester on /no cable). The code will start going thru its sequence as if it is uploading. This will not happen without the jumper. Not sure what that means but it is all that changed anything so far. When those 2 pins are jumpered and the code is moving on the controller screen, pin 2 flickers from green to red. pins 4&5 are red.
Old 08-24-2010, 06:33 PM
Dc I got carried away in the middle of a test and forgot the attachment.
Name:	ScreenHunter_01 Aug. 24 18.11.gif‎
Old 08-24-2010, 06:38 PM
The other settings though the parity doesnt match in this photo. I have tried it on both 1 & 2. That 2nd attachment in this post I am not sure at all about the FIFO or the buffers but I tried it without it and no luck.
Name:	ScreenHunter_02 Aug. 24 18.35.gif‎
ID:	113387   Click image for larger version
Name:	ScreenHunter_03 Aug. 24 18.37.jpg‎
Old 08-24-2010, 06:58 PM
Ok 1 more of the wiring diagram to the RS232 port. It shows a wire on pin 6 described as signal ground. It is physically on pin 7 (which is typically signal ground on RS232 from what I have read). I have noticed in my Dyna manuals, they are vague, sometimes incorrect and have hand written, barely legible and hard to understand notes with arrows and such. According to the latest document I have, pin 6 at the machine is jumpered to pin 5? Pin 6 has no wiring! So much for their guidance. I would think that if I can receive, I must be very close to being able to send. Wouldnt you agree? So since jumping pins 4-5 allows the file to scroll (I would guess this same jumper would allow my pc to scroll also) even though I wasnt transferring anything. Could I download a serial port test analyzer of some kind and get any valid information? With pins 4-5 jumpered pin 2 is green, pin 4 red and pin 5 is red.
Name:	ScreenHunter_05 Aug. 24 18.47.jpg‎
Old 08-24-2010, 07:02 PM
Pin 3 seems to not do anything that I can see. It is supposed to be the receive data pin according to my testers diagram and according to Dyna.
Old 08-25-2010, 12:36 AM
dcoupar's Avatar
Final request...
1. How is your Predator DNC Properties set?
2. How is your cable from the CNC to the PC wired?
  #11   Ban this user!
Old 08-25-2010, 06:54 AM
DC the attachments show my settings, the wiring of the cable was using the pinout provided by predator that you showed me. This wiring arrangement does allow upload but not download (not sure if it is a wiring or settings issue. Today I think I will build a straight thru cable that allows me to jump pins without figuring which pins are swapped. Just to eliminate any error til pin issues are solved. Being that only pins 2,3 4,5 & 7 are the only physical connections. I think pins 2 & 3 and 4 & 5 need to be crossed over and pin 7 to pin 7. The issue of the code starting to scroll only when pins 4&5 were jumpered at the machine might be the same for the pc so that is why I was thinking a 4-5 crossover not a jumper as is shown in the Dyna manual. The predator diagram that you provided wouldnt allow the download at the moment and after opening up my machine and seeing no wires on pins 6,8 or 20, I dont see the need for the jumper. So it makes me a little skeptical of the diagram. However I am also skeptical of anything provided by Dyna as it has generally been wrong. I am really suspicious that pins 4 & 5 are responsible for the initiation of the communication, pins 2 & 3 are the send and receive data pins the way I understand it. Just thinking out loud mostly. I am determined to make it work and it does seem I am too close to go back!
Originally Posted by dcoupar View Post
Final request...
  #12   Ban this user!
Old 08-25-2010, 09:47 AM
dcoupar's Avatar
Your Flow is set to Hardware. Set it to Software. This should allow Predator to send without RTS/CTS handshake.
[IMG] code is Off
predator dnc v8 help andre324 General CNC (Mill and Lathe) Control Software (NC) 3 02-24-2010 06:55 AM
Cryogenic Institute of New England, Inc. Receives ITAR Registration RT_CINE Product Announcements & Manufacturer News 0 11-10-2009 10:50 AM
Just IN- PBC Linear Receives Award for Outstanding Excellence in Quality Standards Pacific Bearing Product Announcements & Manufacturer News 0 03-18-2009 03:44 PM
Predator DNC lyncomputer Computers and Networking 2 09-20-2007 07:13 PM
predator dnc dcr726 Mazak, Mitsubishi, Mazatrol 3 01-15-2005 10:01 PM
