Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-09-2010, 01:34 AM
Schljuutene is on a distinguished road
PC to Fanuc proper actions.
Has anyone here transferred programs from pc to Fanuc Oi? I am curently working with Hartford Omnis VMC- 1270. Recently I get to work with Fanuc Oi controls (Same with the Doosan lynx lathe)- and I have never seen more complicated control. I worked with Haas and Heidenhain controls- that was easy as pie. But here I have this Fanuc and I don't even know the file extension that he is able to read as instead for heidenhain it was (.H). I would appreciate any suggestions which buttons to press on the control to get the program and save it in the memory. Please please help- desperate! The interesting fact was that in the manual all this is located under chapter 8.5 but in the contents the last chapter is 8.4 and then comes 9th chapter. There are so many mistakes. So pissed!
Old 08-09-2010, 06:59 AM
dcoupar's Avatar
Programs must be ASCII text. Extension doesn't matter. (.txt, .nc, .cod, .prg)
Must look like this:
O1234 (PROGRAM COMMENT OK HERE)
N1
M30
Send PC > CNC:
1. EDIT mode
2. PROG function
3. [<OPRT>]
4. >
5. Type in program number if you want it to be different than what's in the program, i.e.: O2234
6. [READ]
7. [EXEC]
8. Send program from PC
Send program CNC > PC
Get PC ready to receive first, then:
1. EDIT mode
2. PROG function
3. [<OPRT>]
4. >
5. [PUNCH]
6. [EXEC]
Old 08-10-2010, 12:47 AM
1000000 thanx! Will try it later today! At least one normal answer!
[IMG] code is Off
Need Help!- Mazak / Fanuc 11T - proper codes to use live tooling GITRDUN Fanuc 0 07-28-2010 07:51 AM
Need Help!- OM G10 - which way is proper? GITRDUN Fanuc 5 04-28-2010 12:30 PM
looking for the proper tool machinehead1970 Mini Lathe 4 04-27-2010 05:36 PM
Proper seating MT3? ozzie34231 General Metalwork Discussion 1 10-18-2008 03:51 PM
Proper use of THK rails mdierolf DIY-CNC Router Table Machines 1 08-18-2008 09:46 PM
