Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-05-2010, 02:13 AM
jake_tb is on a distinguished road
Heidenhain TNC 355 DNC drip feed
Does anybody have a working DNC drip feed set-up with a Heidenhain TNC 355 controller? I have the data com's set-up so files can be up-loaded and down-loaded but when I try drip feeding, I can only get code feeding in up until I press cycle start, then the code stops feeding in to the controller and a "wrong data" alarm comes up. I can keep running the machine up until it reaches the end of the code that loaded in. It seems as though it may be a parameter not set correct so any help would be much appreciated.
Jake T-B
[IMG] code is Off
I-80 drip feed ka67_72 General CNC (Mill and Lathe) Control Software (NC) 1 07-17-2010 06:28 PM
Drip feed or DNC airlid Mori Mills 2 02-17-2010 05:19 PM
Need Help!- Drip feed, DNC? Greg_B Mastercam 7 05-19-2009 11:31 PM
Newbie- Drip feed from PC to Heidenhain moorejc Bridgeport and Hardinge Mills 6 02-03-2009 09:57 AM
Drip feed? MrWild Dolphin CADCAM 1 02-24-2008 10:33 PM
