Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 06-02-2005, 04:06 AM
TORNADO is on a distinguished road
Mazatrol overload detection
Hi , is there anybody out there who can point me in the right direction on how to set power/overload detection up on a Mazatrol Fusion 640MT.
Regards
Old 06-02-2005, 08:32 AM
WayneHill's Avatar
WayneHill is on a distinguished road
What machining process are you doing to cause the overload to happen?
Maybe you need to use a different tool or process that uses less power.
Wayne Hill
www.codemangler.com
Old 06-02-2005, 09:02 AM
The Machining Process That Is Causing The Biggest Problem Is When Drilling Using U-drills. I Have Had A Few Burn Out Destroying The U-drill And Scraping The Component.
Old 06-02-2005, 11:06 AM
psychomill is on a distinguished road
I'd check your process and perhaps even use different tooling like Wayne says.
But for your info, to set the power limits, rpm limits, tool life etc, is done on the tool data page of the 640.
Old 06-02-2005, 01:31 PM
From What I Can See Power Limits Dont Appear To Be On The Data Page ?. But From What I Am Been Told Its All About Using Auxillary Codes m Or Secondary Auxillary Codes a Because The Machine Has A b Axis
Old 06-02-2005, 04:39 PM
From What I Can Now Gather It Looks Like I Have To Insert Data Into The Program Using M Codes , These Range From M370 To M379 Along With A B Code So That The Load On Each Can Be Detected.
Thanks For Looking Guys , Keep The Info Coming.
Regards
Old 06-02-2005, 11:25 PM
WayneHill's Avatar
TORNADO,
Can you describe what your U-drill is? My idea of a U drill is a letter "U" with a diameter of 0.3680 inches.
Material type, machining conditions, coolant type, etc....
After a little web surfing.... Oh you mean a drill with carbide inserts.
I don't use them. They use too much horse power
Wayne Hill
www.codemangler.com
[IMG] code is Off
Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' Haaatschi Machine Problems, Solutions , Wireless DNC, serial port 20 08-22-2010 12:55 AM
Mazak Mazatrol T1 Parts machinist360 General Metalwork Discussion 11 10-20-2006 04:30 AM
Featurecam post for Mazatrol CAM-M2 dmealer Post Processor Files 1 01-27-2005 10:04 PM
Mazak H15 with Mazatrol M2 Steve_rb Machine Problems, Solutions , Wireless DNC, serial port 1 03-19-2004 06:27 AM
Imformation overload, Homebrew CNC thuffner3 Machine Problems, Solutions , Wireless DNC, serial port 8 02-27-2004 11:20 PM
