Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 06-01-2005, 01:18 PM
densman is on a distinguished road
Centroid M -400 help needed
Hello I have a Dah-Lih knee mill with a Centroid M-400 3 axis control upgraded
to the linex system
Once last week , once yesterday and twice today, while running 4 different programs the machine would stop in mid program, the Z axis would start to retract in a feed type speed, then rapid in the z - . fortunetly the first time I was at the machine and able to mash the E stop.
After this happens when I try to jog the Z axis in either dirrection, in any mode(slow-rapid-incremental) it just takes off in rapid speed in the dirrection chosen and wont stop till it hits a limit switch or I hit the E stop
too get it back to normal I go into machine config screen and go in and out of the pid screen and plot screen while manualy rotating the z servo belt.
The last time it happened I was calm enough to notice what the message screen said; LIMIT SWITCH CLEARD
LIMIT:JOB CANCELED
EMERGENCY STOP
After I get it to opperate normally in jog mode I have to power down and restart and home the machine out
After this it will run normal (Z axis limit switches function normal when using tool check function or jog )
Any help with this problem would be welcomed
Dave Ensman
Old 01-30-2008, 02:48 PM
racefast is on a distinguished road
centroid
it sounds like you have a bad encoder on your z axis servo a way to test it is shut the machine down and swap the cable or cables to your servo so put z on x or y what ever is easier and vice versa power the machine up and jog what ever axis is on the z servo and see if it runs away also check the axis with the z cable on it if is fine and z runs away it is the encoder which is located in the end of the servo if z is fine and the other one is running away it is probaly the driver board you can also go into machine parameters and watch the encoder counts for each servo
[IMG] code is Off
Precautions needed while moving CNC Machines cwww Machine Problems, Solutions , Wireless DNC, serial port 8 03-18-2006 11:28 PM
Question about Centroid M-400 control ValleyFab AjaxCNC Control Products 13 08-18-2005 07:37 PM
How much torque is needed? Cold Fusion Stepper Motors and Drives 2 04-21-2005 01:19 PM
What's needed for complete setup? LeeWay Gecko Drives 1 03-09-2005 08:38 AM
what is needed to build a cnc table(plasma) Apples CNC Plasma and Waterjet Machines 13 06-28-2004 06:03 PM
