Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 07-21-2010, 02:08 PM
YTMBOSS is on a distinguished road
Fanuc 18-M communication problem
I have a Johnford SV45 with a Fanuc 18-M control. We bought it about a year ago and had to let it set for a while. Back in the winter I lost all the Parameters because the backup battery died. So I got the parameters downloaded from my labtop using the RS232 port. Now I have time to mess with the machine and I can't get it to download a program. I'm using the same cable I used to download the parameters a while back and SDNC software to communicate. I go through all the process and when the controller flashes LSK I send the program and nothing happens at controller, it continues to flash LSK. Any suggestions on how to communicate through the RS232, that is how I communicate with my other machines.
Also this machine has a labtop with ethernet that came with it. I have not been able to get it to communicate. I have all the parameters set for RS232. DO you have to change any para to use this ethernet. It has a Black Box Mini 10 base T Transceiver hooked into the AUI CD27 slot inside the cabnet. ANd the computer has a hyperterminal setup to communicate through. I am not familiar with ethernet. I have been on the phone with FANUC and Black Box with not much luck yet.
Any help is greatly appreciated
Old 07-21-2010, 03:44 PM
Nevermind, I've been working on this machine for 4 days and just now figured it out. I had a pin pushed back to far in one of my RS232 plugs and had the parity set at odd when it needed to be even.
Anyone know anything about the ethernet box hooked up. Is it something I need to look into since it is on there.
Old 07-21-2010, 07:46 PM
dcoupar's Avatar
The laptop might have been used to connect to a Data Server. If so, there should be a unit that looks like the attached .jpg.
Then again, I could be all wet.
Name:	Data Server A02B-0213-J001.jpg‎
[IMG] code is Off
Communication problem through CH 4 in Fanuc 21i-TB control humak16 Fanuc 13 08-12-2010 05:12 PM
Communication problem with X4+ shannow Syil Products 47 02-23-2009 04:43 AM
Fanuc OT communication problem ECM2004 General Metalwork Discussion 4 06-07-2007 07:05 AM
Fanuc Om Communication Problem aghobby Fanuc 13 02-27-2007 12:01 PM
Communication Problem LEGCNC Machine Problems, Solutions , Wireless DNC, serial port 1 05-29-2006 08:34 PM
