Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 06-11-2010, 04:56 PM
Trell1 is on a distinguished road
IKEGAI AX25Z turret fault No code
I have a JMD IKEGAI AX25Z The turret has a random fault with no code after 10 minutes of power off time will reset and operate fine for one hour, one day, 20 minutes, etc. Fast power recycles to reset will fault immediately. The fault will happen when the turret moves out before rotation, it will make approximately ¼ inch of movement out. It is not the proximity sensor. We have changed the A20B-1000-0940 card thinking thermal as when cooled itself, re-operated. No luck. The programs have not been modified and have run for years, and will fault randomly on any of them during the, tool turret change.
Several years ago I fixed the sequencer servo for this turret (Index Pulser) as I do board level repairs as my profession as anyone knows these intermit-ants can be troublesome
[IMG] code is Off
IKEGAI AX25 TURRET hiiesalu Fanuc 3 03-05-2012 07:40 PM
Tool Turret Fault Alarm on TL-1 with no Turret? Edster Haas Lathes 10 02-08-2010 08:35 AM
Need Help!- Turret shuttle fault jprobst Haas Mills 11 09-23-2009 10:05 AM
Appreciate Help - Duplomatic Turret Fault Tony2pies Cincinnati CNC 1 08-31-2009 10:56 PM
TM 1 turret rotate fault f1jdm Haas Mills 4 11-28-2007 03:00 PM
