Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-29-2010, 12:58 PM
joshuac is on a distinguished road
help with fanuc i series
Hello people.
First i want to say, this forum is very very good, speciall thanks to all.
I have an machine with a Fanuc i series control (see attach pictures)
My problem is: i can't do DNC mode.
I can transfer small files to memory of machine with rs232 cable, but i can't do DNC for big files...
it's possible, if someone know, how to do??
regards.
joshuac
ID:	108037   Click image for larger version
Old 05-29-2010, 02:03 PM
frigoteknika is on a distinguished road
hello
we hawe the same problem with murata wiedemann turret punch,ween we make big programs we devide these in .PAT
HAWE NICE DAY
Old 05-31-2010, 02:29 AM
hello
i think it's possible we active DNC function, i don't know how... I try to change some system values but without results
regards
joshuac
Old 05-31-2010, 10:57 AM
dcoupar's Avatar
If you select TAPE mode, does RMT display at the bottom of the screen? If so, try turning on SINGLE BLOCk switch and press CYCLE START. Does LSK flash at bottom of screen? If so, send the program from PC to the CNC. You should see the program displayed on the screen.
Old 06-04-2010, 02:35 AM
Yes it works.
thanks @dcoupard i don't know what is TAPE mode...
Now i can do big programs
regards
joshuac
[IMG] code is Off
Help with Fanuc Series 0-M accramachine General Metalwork Discussion 5 10-25-2009 05:50 PM
Fanuc O-T Series zanellan Fanuc 3 07-13-2009 09:10 AM
Newbie- FANUC Series 18-M Kristoffersen Fanuc 2 01-16-2009 04:17 PM
GE Fanuc Series 18-M MGT Fanuc 5 02-20-2007 12:02 PM
Fanuc Series 10 kayleesdad Fanuc 22 05-09-2005 02:30 PM
