Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-28-2010, 03:33 PM
dhenke is on a distinguished road
Unhappy IOGEAR GBS301 Bluetooth + Cinco Edit
I'm trying to set up a simple / cheap DNC solution using the IOGEAR GBS301 Serial to Bluetooth adapter. I'm using Cinco Edit for DNC. I'm able to establish a connection with the bluetooth adapter that's hooked up to a Fanuc H400. When I attempt to receive, I get garbage from the machine. The software receives ASCII trash in the same format as the program I'm trying to send. I've tried messing with baud rate, data bits, parity, stop bits, you name it.
If anyone has any experience with this adapter, please let me know. It appears that I'm receiving the wrong data, but a connection has been established.
Also, this adapter doesn't support DTR but does support RTS, so I've been using that.
Old 12-29-2010, 09:04 PM
risesun is on a distinguished road
I have this same problem with IOGEAR GBS301 Bluetooth.
I think this is not for CNC.
For cnc try from Wireless Serial Port Adapter Applications - Wireless RS232 - Bluetooth to RS232 - CNC machine
Tags
bluetooth, dnc, iogear
[IMG] code is Off
bluetooth serial port plastibob Haas Mills 2 12-17-2009 06:11 AM
bluetooth to rs-232 questions ze9900 Haas Mills 1 03-05-2009 11:50 AM
bluetooth! draughted General CNC (Mill and Lathe) Control Software (NC) 1 10-10-2007 01:48 AM
USB Wireless Bluetooth on PC CNC Controls WayneHill Machine Problems, Solutions , Wireless DNC, serial port 4 03-12-2007 11:00 AM
RS232 VIA bluetooth, Sucess. Loading Haas Mills 2 09-28-2006 12:46 PM
