Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-30-2010, 07:02 PM
bjcrevier is on a distinguished road
rs232 on AB 8200 control
Hi, Trying to upload and download programs on a B&S CNC screw machine equipped with an Allen Bradley 8200 control.
Can load program from pc to control, but don't know the command to enter to go from control to pc.
Anyone know how?
Old 05-25-2010, 10:26 AM
skrueger is on a distinguished road
Do you happen to know how to wire up a laptop to the RS232 port on a Toyoda MOD# GPNJ5A32x10 grinder? S# RC3294 MFG# TG2405-1 please?
It has a toyopuc PC-1 system.
Old 10-23-2010, 09:18 PM
pipes is on a distinguished road
Try CT,CY
Did you try CT,CY,filename ] (transmit) after setting the output to RS232 port A with PD,232,A]?
If this works and you want to set things back to the parallel in/out use PD,9] (parallel C,D)
If you need to change baud rate try PD,232,5] for a baud rate of 4800.
Baud rates: 0=110, 1=300, 2=600, 3=1200, 4=2400, 5=4800,
6=9600
[IMG] code is Off
Need Help!- OM Control - RS232 - Parameter SHORT_JOHN Fanuc 1 04-15-2009 06:02 PM
Control Mate RS232 Problems lizvern Commercial CNC Wood Routers 1 03-11-2008 11:02 AM
Allen Bradley 8200 control gnmachine General CNC (Mill and Lathe) Control Software (NC) 4 04-05-2007 07:19 PM
Mazak EIA Control RS232 Connections jonbcnc Mazak, Mitsubishi, Mazatrol 2 11-20-2006 02:34 PM
Help! RS232 Communication to Fanuc 3T Control m1_machine Fanuc 5 10-30-2006 02:08 PM
