Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-16-2010, 04:04 PM
roger_e is on a distinguished road
Ncnet lite Okuma 500l-g
Ncnet says it is transmitting but we get no verification on the okuma....when we punch "Read" on the Okuma we get the message "RS232 not ready"
Any help would be appreciated
com channel: serial port
port number:1
baud rate: 2400(machine and PC)
Old 04-17-2010, 11:45 PM
gm3211 is on a distinguished road
Okuma
Try punching from the machine first so you can verify you have a good file and known format.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Old 04-18-2010, 09:24 AM
I haven't done serial communications since the 1990s, can you elaborate a little?
We are using the correct file extension, .min
Are you talking about what is actually in the NC file itself?
How do I know if I am getting any coms at all?
Old 05-28-2010, 06:32 PM
BuiltMachine is on a distinguished road
wiring
The machine will tell you if it thinks no wire is connected.
It will do it by that alarm rs232 not ready.
The computer will not say there is no plug, but the machine will.
You are able to get on this forum, so I assume you are tech enough to plug in the cable.
That means the setup info is wrong or the wire is not jumped right.
You have some work ahead of you if you can not readily find these answers.
If you are good at this stuff you will find it quickly.
If not you should call a tech.
The setup would be stop bits, handshaking, baud etc.,
The wire jump deals with the actual wire in each plug connecting to the wire in the other end of the plug. They do not all go straight thru!!!
Check in these 2 directions. (or call the previous post he left a #)
[IMG] code is Off
Problem with NCnet Lite.... gearsoup General CNC (Mill and Lathe) Control Software (NC) 4 06-24-2011 12:29 PM
Need Help!- Ncnet Lite katsbobo General CNC (Mill and Lathe) Control Software (NC) 25 02-28-2011 04:24 PM
ncnet lite krustykrab Machine Problems, Solutions , Wireless DNC, serial port 5 02-10-2010 01:15 AM
Need Help!- NEED ALLEN BRADLEY 8400MP PARAMETERS FOR NCNet lite software Msobalvarro General CNC (Mill and Lathe) Control Software (NC) 0 03-03-2009 01:15 PM
Okuma CNC OSP 500L-G rajappa Okuma 0 06-03-2008 05:36 AM
