Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-06-2010, 01:11 PM
ToolBreaker is on a distinguished road
Exclamation Proto Trak M3
I have had an m3 for 15 years with just the occasional problem (servo amp etc..) about 10 months ago I had to replace the pendant ($1000!!!) now im getting a harware lock error that says "SWI HARDWARE KEY IS BUSY OR NO KEY IS ATTACHED. MAKE SURE THE KEY IS SECURELY CONNECTED TO PORT LPT1 THEN RETRY OPERATION" I've replaced both serial cables, and reseated ALL connections on the control and the slave unit on the back. Southwestern says the control needs to be replaced, which i find hard to believe after ten months of use by a machinist who is OCD about keeping his machine spic and span. I was wondering if anyone has run across this before. Thanks for any help you can provide, right now we cant afford to throw out another grand to have the same thing happen in ten months, I cant even get them to sell me a warranty.
Thanks!
Old 04-08-2010, 08:53 AM
robert copeland is on a distinguished road
where are you located at
Old 04-09-2010, 07:41 AM
Norfolk Va
Old 04-09-2010, 07:47 AM
call thomas harpine 4104871364 he could help you out
Old 04-09-2010, 12:03 PM
Thanks Alot
Tags
hardware lock, proto trak
[IMG] code is Off
PROTO-TRAK Gary55Ford General Metalwork Discussion 21 01-24-2012 07:40 AM
Newbie- Proto Trak Plus seapacer2 Bridgeport and Hardinge Mills 2 03-06-2010 08:08 PM
Need Help!- Proto Trak MX2 mess1207 General Metal Working Machines 1 12-02-2009 04:09 PM
PROTO-TRAK Gary55Ford Fanuc 2 01-25-2008 06:47 PM
Proto Trak? Garage Shop Bridgeport and Hardinge Mills 5 01-31-2007 10:38 AM
