Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-02-2010, 06:23 AM
zapata77 is on a distinguished road
Mach3 configuration for A3977 3 axes b driver
Hi guys,
Im from Portugal, and i am new in this CNC world.
I'm having some difficulties setting up my CNC KIT with mach3. I do not know what the problem is, since the controller was already purchased mounted (and tested) and I just had to solder the wires from the motor terminal (already included in the Zen kit) to the connectors to plug in the controller. I have inserted the basic configuration of mach3, as indicated in the documentation provided by the seller (the same options on the print screens on documents) and...nothing! The engines give no sign of life. Does anyone have or know anyone who has this driver that can share is experience with me? Is the cable I bought appropriated? I will appreciate any help. The motors are 3 Nema17. When I have all connect and when I power the controller driver, should i feel some power in the motors? Maybe a slight tremble…i dont know how to explain, but fell the motors with electrical power…? I know they only move with the software coordinates, but I should felt that? Thanks
ID:	104295   Click image for larger version
Name:	Picture 005_2.jpg‎
ID:	104296   Click image for larger version
Name:	Picture 007_2.jpg‎
ID:	104297   Click image for larger version
Name:	Picture 008_2.jpg‎
Name:	Picture 010_2.jpg‎
[IMG] code is Off
Need Help!- Camsoft with Galil Basic Configuration Settings for 3 axes servo set up Arul prakash CamSoft Products 13 06-28-2010 09:49 AM
PMINMO A3977 or L297-8 Driver? cnc-newb Open Source Controller Boards 10 01-19-2009 06:43 AM
Mach3 for Maxnc 5 configuration wushu2266 Mach Mill 0 07-06-2008 12:12 PM
A3977/Mach3 Direction changes randomly kiltjim Open Source Controller Boards 9 12-08-2007 08:04 PM
a3977 driver TigerPilot Open Source Controller Boards 1 03-26-2005 08:18 PM
