Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-28-2005, 01:44 PM
SFA SFA is offline
SFA is on a distinguished road
Mazak L Alarm
I have customer who has a Mazak Laser with L controller. They are trying to setup CNC communications and getting an alarm upon punching out. They tried to call Mazak for help yet no one has called back.
The alarm is 301 which means nothing to me. If someone has a clue or even a list of alarms codes, please fax it to me @ 619-461-5918.
Also, any wiring diagram would be helpful too. We have wired the cable up to use hardware flow control but maybe this is related to the alarm?
Greg Mercurio
Shop Floor Automations, Inc.
www.shopfloorautomations.com
(619) 461-4000 Tel
Old 04-28-2005, 02:01 PM
Al_The_Man's Avatar
Is it a Mitsubishi or Fanuc control? If so do you know what system #?
For the communication, either Fanuc or Mitsubishi, if they have brought the communication out to a 25p D connector then it should Be standard RS232 and you can jumper the handshake out both ends 4-5 6-8-20.
I am not familier with the Mazak laser so this is general information. For e.g. the error 301 on recent Mazak/Mitsubishi is 'single block on' but I doubt if that is the case here.
Old 05-26-2005, 12:52 AM
SFA SFA is offline
It was a cabling issue - the machine did not have the correct jumpers. We sent them a hardware handshake Grizzly Cable and it worked great. Thx for the attempt!
Greg Mercurio
(619) 461-4000 Tel
[IMG] code is Off
Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' Haaatschi Machine Problems, Solutions , Wireless DNC, serial port 20 08-22-2010 12:55 AM
Mazak 8G M/C,mazatrol eia-t, z axis stuck imwllc Mazak, Mitsubishi, Mazatrol 7 09-07-2009 10:48 AM
Mazak Rotary Turret Switch reBuild Al_The_Man Product Announcements & Manufacturer News 6 04-11-2007 10:21 AM
Probing - Mazak Fusion CFisher Digitizing and Laser Digitizing 1 06-07-2005 11:02 PM
Servo Alarm linesman 71 Haas Mills 1 04-28-2005 08:45 PM
