Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-21-2005, 07:50 AM
mrfixit is on a distinguished road
Acramatic 2100 problem
Have problem on a Cincinnati Arrow with a A2100 control. The z-axis feeds at a really slow slow slow rate following a G84.1 tapping cycle. The only way around it is to move the Z-axis a small amount then move X&Y axis a smalll amount then the Z-axis will move freely at full rapid. See example:
G84.1 YADADADA
G0 Z10.
G0 X10. Y5.0
The G0 Z10. line should move the tool at full rapid ( it does on my other machines with the A2100 control).
I've tried a G80 and even a G01 with a high feedrate - no hlep!
Is there a setting or is this a software issue?
Old 05-22-2006, 08:28 AM
wmc wmc is offline
wmc is on a distinguished road
Acramatic 2100 help
You have probably tried this but here goes anyway.
The G01 should cancel the G84 tapping cycle, however
you may want to try a G80 canned cycle cancel to see if this
makes a difference.
[IMG] code is Off
Okuma LC-20 Threading problem Gunner Machine Problems, Solutions , Wireless DNC, serial port 13 12-13-2011 10:11 PM
CNC gantry Machine shows problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 15 04-25-2005 03:02 PM
Infra red communication problem jtree83 Computers and Networking 0 04-17-2005 10:06 PM
servomotor problem Alex S.A Servo Motors and Drives 16 12-24-2004 01:08 PM
Fadal VMC4020A axis problem cwww Machine Problems, Solutions , Wireless DNC, serial port 16 12-01-2003 11:07 PM
