Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 10-05-2009, 01:17 AM
jacampb2 is on a distinguished road
Showing off a bit-- Acrylic engravings
I bought myself an 1981 BP S2 CNC almost 2 years ago. Converted it to PC controls running Mach3, leadshine drives and CNC4PC BOB. Anyhow, I use it for a lot of things, but mostly artsy engravings and such. I have mostly devoted my work to a small online community obsessed with older mobile audio amplifiers made by Phoenix Gold. So far they have kept me in more work than I can keep up with between the hobby shop and my shift job. Bellow are some of my nicer large pieces.
I did the shroud on this one, not the amp itself. The shroud is a .125" aluminum trim ring, the acrylic is .25" area cleared to sit flush in the aluminum frame. IIRC, size is 15x36.
I did the aluminum shroud on this one, as well as the acrylic, similar to the above, but this one measures 15x18. I also did the lighting, yellow, orange, and red LEDs, 16 in total to get the gradient. The design was customer requested, but I also did all of the vector artwork. I appologize for the blurry pics, they were submitted by the customer...
And this one was built for me alone, it is going to be part of a pair once I finish the other. I built the case, end plate inserts, acrylic top, and all of the connectors and internal electrical bus. The amps inside also have some power mods.
Anyhow, that is most of my best stuff. I have lots more, but these were my favorite projects. I hope you all enjoy them!
Later,
Jason
Old 10-05-2009, 02:23 AM
grahamshere is on a distinguished road
very nice, love the fire bird, now that looks cool. love to see more.Graham
Old 10-05-2009, 03:22 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Very cool projects!
Are the acrylic cuts on the outside, or did you mirror them on the inside to keep the outside smooth?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 10-05-2009, 04:29 AM
Thanks guys! I'll post up more as I make more. Most of the stuff has been simple text based logos, these are by far the most detailed work I have done.
The artwork for the acrylic is all mirrored and cut on the inside. I can't tell you how many pieces I have scraped after I began cutting and realized I forgot to mirror it. I normally do all the tool paths non mirrored so I can get a preview rendering to submit to my customers. Most of the time I'm cutting these coming off my shift work job, and half the time that means no sleep after a midnight 12hr shift-- well, you get the picture, things like remembering to mirror and regenerate toolpaths sometimes slip my mind...
I get a lot of questions on tooling, especially for the acrylic since it is not an exactly happy plastic to machine, so here is a brief outline. I use Onsrud cutters almost exclusively for the acrylic, I started out with normal router tooling from the hardware store, and although carbide straight cut router bits do okay, the Vee bits for wood working aren't that great and cause a lot of frustration with acrylic. The Onsrud cutters are a fair bit more expensive, but take a lot of headache out of it. I use compressed air only for coolant and clearing chips, and I use a little bosch "colt" 1hp WLS palm router in an outrigger on my quill for the plastic work. Router set on speed "3" which as close as I can tell is about 10000 RPMs and feeds of ~ 50IPM w/ a 1/2" Vee bit.
Later,
Jason
Old 10-05-2009, 06:28 AM
Tsooko's Avatar
Tsooko is on a distinguished road
Wow!
I love it. Keep it up and post more pics please.
Ted
If you are going to be a Bear... then be a Grizzly!
Old 10-05-2009, 08:22 AM
WynPro is on a distinguished road
Outrigger setup?
Nice work,
I do some engraving running the machine at 3200 RPM Redlined and would be interested on seeing a picture of your router setup on the quill. It would be nice not to have to redline the machine anymore and increase runtime.
Thanks,
Dave
Old 10-05-2009, 09:09 AM
Horsedorf is on a distinguished road
OH my, that is superb! Thumpin' car stereos tha tlook great.
I'd love to know how you got the different colored reflections in the Phoeinx though, some areas were orange the other's yellow, how did you do that? That looked fantastic!
Rick
Old 10-05-2009, 11:55 AM
Radigan is on a distinguished road
Great art work. I have done some machining on acrylic and it can be trying at times to say the least. Very nice work.
Old 10-05-2009, 01:58 PM
Originally Posted by jacampb2 View Post
... I use compressed air only for coolant and clearing chips.....Jason
Cast acrylic should be a 'happy' plastic to machine but extruded is difficult.
Have you tried a very fine mist of soapy water as coolant/lubricant? It is necessary to be careful with what fluids get near acrylic but very mild liquid soap is okay.
Old 10-05-2009, 02:43 PM
I have had some luck using WD-40 as a lube. Kind of messy but it worked.
  #11   Ban this user!
Old 10-05-2009, 08:09 PM
Here is the only pic I could find of it. It isn't pretty, the "outrigger" itself has been cut up and modified 3 times. It used to hold a little air die grinder which I found spectacularly useless, then a "rotozip" spiral saw which required having it's bearings replaced every two weeks or so-- I crashed it bad one day and bent it's spindle, so I bought the bosch and it works very well. It has been going for about 6 months and is just now looking like it is going to need a rebuild. I have all the parts to make a ER32 HS spindle insert, I just need time to finish it up. It will be belt driven from a big 2HP router.
Both of the amps I did for customers are going to be wall art. The Big black one is already in a beautiful frame and hanging on the guys wall. The one with the Phoenix is going to be used in a home theater room and framed and mounted as well.
The color gradient was all trial and error. I didn't even know if it would be possible to get it to come off remotely close to what I envisioned. The leds are grouped by color along the long edge of the acrylic, the reason the bird lights up different colors is only because the cut is grabbing the light, and it is more in line with one color than the other. I searched online to try to find out if a gradient was possible, and as far as I can tell no one had tried it, and if they had, they had not posted up their results...
I have machined some cell cast acrylic, and really didn't notice as much difference as folks claim. From what I understand, it is rare to find cast in the thinner acrylic sheets I use. I have been using extruded acrylic almost exclusively. The only time I have seen it getting even a little bit gummy w/ the onsrud cutters is when I am using a Vee bit and a very shallow cut.
I've tried windex, which works pretty well for cutting fluid, but I found that compressed air is nearly as good, and it has the benefit of not destroying the MDF spoilboards I use for backing up the work.
You need to be careful with oils and acrylic or polycarbonate. From what I understand, a lot of fluids won't impact them right away, but will cause crazing and hazing over time.
Later,
Jason
  #12   Ban this user!
Old 10-05-2009, 10:56 PM
rbritt is on a distinguished road
It is sometime since I did any plastics work but what really stopped the "sticking / re-welding" of chips for me on plastics was a mist sprayer so it feed coolant thru an adjustable venturi into a small air blast. This all depends if your machine is Liquid proof of course. not a good idea around a mdf frame
Regareds Rob B
Not Working- Last post not showing grinder_gary Forum Questions or Problems 1 02-04-2008 09:50 PM
What are photo engravings worth? tdnp WoodWorking 17 12-21-2007 10:33 AM
Some of my test engravings Alu. 6082 giggler Engraving Machines 2 07-10-2007 11:42 AM
None of images showing up rustamd Forum Questions or Problems 3 03-16-2007 12:37 PM
