Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
  #13   Ban this user!
Old 10-13-2009, 04:31 PM
vger's Avatar
vger is on a distinguished road
cyclestart,
I was intending to suggest that only the mechanism under the sand table rotate. The table top itself would remain stationairy. Just rotate the single motor, screw, and magnet assembly attached to the turntable.
A thought occured to me about how to clear the "drawing".... suppose you mounted motor with an offset weight to the sand table as a vibratory eraser. Probably have to shock mount the table to allow a bit of movement, maybe with springs. Orient the motor shaft verticaly so the vibratory movement of the table would be circular in motion to erase the image.
Have a great day
Steve
  #14   Ban this user!
Old 10-14-2009, 08:50 AM
cyclestart is on a distinguished road
Ah, I went back and reread you're previous post. It adds some complication but solving design problems is half the fun The drives I'm using are very sensitive to any current disruption between drive and motor, making me a nervous regarding making any indirect. connections. Avoiding slip rings would be ideal.
I'll hold off on bothering you for parts for the time being
thanks
jeff.
Anyone who says "It only goes together one way" has no imagination.
  #15   Ban this user!
Old 10-14-2009, 10:09 AM
low_48 is on a distinguished road
I've looked at these machines as well, but not inspired yet to build one. I had the idea that maybe glass beads would be a preferred material instead of sand. Or maybe a sized grit abrasive. Did you use something like that, or play sand?
And for the analog version;
http://www.thinkgeek.com/geektoys/cu...d/?cpg=froogle
  #16   Ban this user!
Old 10-14-2009, 11:54 PM
The sand is very fine grit from an art supply store. I don't know what others are using or what type of size of grit is ideal.
That pendulum is so cool
I'm going to buy that as a Christmas gift. Of course I get to play with it first !
  #17   Ban this user!
Old 10-15-2009, 05:13 AM
garagefela is on a distinguished road
Hi there Cyclestart and everyone watching this great thread,
Cycle, just having look at the pictures of the patterns you have done and one thing seems to stick out, it appears that the edges of the patterns are not very well defined.
It looks like the sand is very fluid and sort of slumps back down after the ball has passed through and is not giving clean edges, sort of smudgy.
I once saw this great little doco on those uber talented guys and girls that do those massive beach sandcastles, animals, buildings just about anything that you can think of and a question was asked of them and it was along the lines of "how does it stay up"?
The answer was in the shape of the grains of sand, round grains of sand wont stick to each other very well but a cubic shaped grains will or whatever other shapes there are. ( experts please jump in) Not exactly sure of what shapes there are but you get the drift.
Having grains that won't easily slide past one another should help with the definition a bit.
Top job on the table and am eagerly waiting to see some cool designs done on it.
Cheers M
No, Little-Johnny, pomegranate is not a type of English stone.
  #18   Ban this user!
Old 10-17-2009, 09:10 AM
vger's Avatar
Jeff,
When I get the chance I'll do some testing on the rotary coupling. It has multiple sliding contacts on each circuit and may not have much if any loss of contact while turning. I'll run current through it and observe it with my oscilloscope for any noise. It may be a couple of days before I can get to it.
Steve
First Attempt help sYmbot2 CNCzone Club House 2 09-10-2008 05:55 AM
New Machine Build- my first attempt v2tiller DIY-CNC Router Table Machines 2 06-28-2008 12:44 AM
first attempt corrie Musical Instrument Design & Construction 10 01-05-2008 08:22 PM
My first attempt Caprirs Vectric 4 08-28-2006 02:27 AM
A axis attempt Konstantin General Metal Working Machines 2 07-26-2006 05:36 PM
