Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 04-10-2009, 08:17 AM
GEORGETOUBALIS is on a distinguished road
CNC doming machine
I finally finish the doming machine project.
The machine.
Parker linear motion tables 406 & 404 series
Drives 750 OEM
Motors nema 34
All from ebay.!
Mach3
Old 04-10-2009, 10:42 AM
beone is on a distinguished road
Wow George!
I like your machine. I have a cnc router and use it to make patterns for my aluminum foundry. We often fill the castings(medals etc) with epoxy. I will have to explore this as a way to automate this arduous part.
Thanks.
Dave
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Old 04-10-2009, 11:05 AM
One of Many is on a distinguished road
Very impressive George. Your metering of the liquid seems pretty accurate. Is that a custom valve?
We use some darned expensive metering valves from loctite that can handle MEK based glue that ruins rubber seals and diaphrams of others we have tried. The nice feature these have is suck back effect to minimize stringing and drips. Very complex internals with the metering control and pneumatic actuator.
I have an 18" x 18" x 12" 3 axis assembly that may become a glue path apparatus very similar to your applicator. It is all Parker Daedal ballscrew slides, with Compumotor motors and drives that someone scrapped at a friends scrap yard.
The plan would be to make it assistive for mobility and visually challenged employees. Loading and unloading a pallets of parts would eliminate the hand gluing and alignment issues.
Nice video!
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 04-10-2009, 01:07 PM
W
DC
thanxs DC..!
I have to tell you that I build a small cnc ROUTER to machining a lot of part for the big one!
The valve is a pinch valve that I build!
The pumps this a strange story!
I use Viscotec Progressing Cavity Pumps Which cost about 5.000$ each.
I need 2 since the doming application is a two component.
I found from ebay 5 for 50$ each (3 new 2 used).
I was Lucky!
George!
Old 04-10-2009, 04:16 PM
Originally Posted by GEORGETOUBALIS View Post
thanxs DC..!
I was Lucky!
George!
Our system didn't require that precise of metering the auger or screw pump will give. We use a large pressure pot that holds a 5gal bucket of the adhesive. I needed to have a valve that was positive off without leakage, drips or strings. This fit the bill without complicating the mess with electronic drive circuity. Just a simple pneumatic micro-switch on a linear cam.
Here is a look at the Loctite metering valve we use. Last ones we purchased were $950usd or so with rebuilds/repair about 1/2 that. That looks cheap compared to those pumps! You did get lucky. Careful though, that ebay
Loctite 97113
DC
Old 04-11-2009, 05:44 AM
Loctite 97113
DC
One component dispensing is very easy process compared to 2-components.
Last year I purchased from Ebay the same valve as you (never used in there official BOX).
I want to make a 2 part shutoff valve by connecting some way 2 one part but then (after a month) I found 2 Garco 2-part valves (2500$ per valve) for only 250$. And I use these now.
I wiil sell sometime soon the Locktite valves! I do not need them any more!
Ebay is a paradise!
I will spent about 18.000$ the last 2 years and I have
A. 2 cnc tables
B. components to build another 2 much bigger (motors, drives, power supply, sensors, linear tables, linear rails, ball screws ........everything.
C. 4 dosometric systems 2 for one component 2 for 2-part component
90 orders in total ! with no problem at all.
I think you have to give ebay a try!
Old 04-11-2009, 10:00 AM
Yes, I would say that 2 part dispensing does add some complexity, not to mention the ability to cure in the nozzles. Cleaning them well must be a chore?
I have used Ebay on about the same number of trades over the last oh, 10-12 years. Most good experiences but not all . There is the occasional thief on the prowel that don't care if you like what they sell. Once they have the cash, they intend to keep it, regardless if the buyer doesn't consider it a fair trade on a sight unseen sour deal. Ebay policy is no help, even when the sellers listing includes a return/refund policy if you are not satisfied.
DC
Old 06-21-2010, 06:03 AM
electrochem9 is on a distinguished road
quotation Required
Dear Sir,
Pleasr Quote for scripting Doming machine.please give your technical literature.
YouTube - Doming application small decorative labels
The machine.
Drives 750 OEM
Motors nema 34
All from ebay.!
Mach3
Old 06-21-2010, 11:44 AM
Senna's Avatar
Senna is on a distinguished road
George,
I was fascinated with the video!!! Your brilliant application of a CNC process works to perfection!
Senna
aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
Old 07-03-2010, 03:46 PM
honeychico is on a distinguished road
HOW MUCH IS YOUR DOMING MACHINE? OR CAN YOU HELP ME BUILD ONE FOR MYSELF?
  #11   Ban this user!
Old 08-24-2010, 07:36 AM
nirmal kumar is on a distinguished road
Smile Director
The machine.
Drives 750 OEM
Motors nema 34
All from ebay.!
Mach3
Kindly send us quote
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 04:54 PM
Another machine rigid tapping (stepper machine) samco LinuxCNC (formerly EMC2) 10 04-10-2009 08:21 PM
sell CNC Woodworking Machine,CNC Advertising Machine zhangrui1588 Product Announcements & Manufacturer News 0 05-30-2008 09:43 AM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 10:37 PM
