| Machine Created Art Discuss art created by machines here. |
| How do you hold a pc. so small? Melt the wax to the table? I can't say I've seen anything machined with features so small. Good job. Used to do a lot of work for Applied Materials. Which used a PVD (Plasma Vapor Discharge) process over a stencil to etch the features down to 65nm . It's amazing how small things are getting. ![]() http://www.appliedmaterials.com/prod...?menuID=12_5_1 |
You machined that with a MaxNC machine? That's really impressive! Scratch that. It's impressive no matter what machine you used. How much modification did you do? Is it running the stock steppers, or did you do some upgrading? |
| Damae, Fixittts Max NC is highly modified, the only part that is original is the frame. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
#10
| Fixitt, do you use any type of oil or lube to help clear chips? I noitce wax tends to gum up and melt on me. And how do you get such fine detail? you must use .001 offset per pass? Very slow speed? great work .. ~Steve |
#11
| sorry guys, been really busy lately. as for the wax, there is special carving was for the jewelry industry. It has alot of plastic in it which aids in the carving/machining process. Cuts way down on the melting of the wax. as for the coolant, sometimes i rough in the wax with a 1/16th ballnose endmill then I will switch to a 15 degree conical bit with a .005 thou inch tip. before running the finish pass I will put some mineral oil on the wax which helps in keeping the swarf from compacting into the small areas, and helps with heat. *EDIT* to help in the clean up of the mineral oil and chips, I use dish soap in an ultrasonic cleaner it helps remove the oil, then I blow off whats left. |
| Computing Motor Size | bdrmachine | General Metal Working Machines | 0 | 11-21-2007 08:46 AM |
| Computing Cable Rotation From XYZ Point Data | FishGuy876 | General CAM Discussion | 0 | 09-17-2007 02:55 PM |
| help with micro stepping | chrisw765 | Xylotex | 1 | 03-05-2005 07:26 AM |
| D&M Computing CNC 9 Lathe Info??? | TD1932 | General Metal Working Machines | 1 | 10-11-2004 04:16 PM |
| micro-edm | roysol | CNC Plasma and Waterjet Machines | 1 | 10-15-2003 02:01 PM |
