Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 12-08-2007, 06:41 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question My First Project. Ohhhh Nooooo
This is my 1st cutting project.
I had a friend draw it up and I think he used TurboCad, and gave me this output DXF file that is attached below. It is about 8" X 20" cutting 1" thick foam, using 1/4" bit.
I opened LazyCam and it imported OK, clicked Cleanup and a few things happened, saw a few lines disappear.
Then saved to Mach 3 and again it was on the screen and looked OK.
However when I ran it there were many cuts where there shouldn't have been cuts. And it didn't cut in a very efficient way, a partial cut here, go to another spot cut some more then back and forth jumping all over. The biggest problem is that it was cutting where it should not have.
Hmmmm
Could someone take a look and see if this can be saved.
Hager
Old 12-08-2007, 06:59 PM
ger21's Avatar
Try this one. I cleaned it up a little.
Old 12-08-2007, 07:16 PM
Mr.Chips's Avatar
Gold Member
Wink IT WORKS
IT RAN PERFECTLY!!!!!!!!!!!!!!!!!!!!!!!!!!! No nore bad cuts, but the cut pattern wasn't very efficient. Discuss later
Have to run my wife is calling me to go to a pot luck.
Thanks so much
Hager
Any use for these in DIY project? Guy Smiley General Electronics Discussion 7 05-16-2009 10:36 AM
My little cnc project... GERY CNC Wood Router Project Log 82 12-14-2008 10:46 AM
My cnc project llilrex DIY-CNC Router Table Machines 1 11-05-2007 08:17 PM
Hi everybody! Here's my project! davidbue Benchtop Machines 2 06-21-2007 03:27 PM
This would be a fun project... jdbaker Hobby Discussion 4 11-13-2006 01:19 AM
