Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 03-31-2007, 12:46 PM
Lawrence H is on a distinguished road
DXF files of old stone floors?
Hello,
Does anyone know if there is a company out there that sells finished dxf files or high def drawings of old stone floors (and or other walls and floor surfaces)? I would like to create the look of an old stone floor with a 5' x 10' router table.
Any information with regards to this topic would be greatly appreciated!
Lawrence
Old 03-31-2007, 10:55 PM
todd71's Avatar
todd71 is on a distinguished road
This might help http://www.spiralgraphics.biz/viewer/index.htm Depending on your software you may be able to model from the brick textures.
Good luck,
Todd
www.innovative-accents.com
Old 04-01-2007, 06:23 PM
todd71's Avatar
I was able to model this off a spiralgraphics texture in ArtCAM. Could look pretty cool as a wall panel, with the right finishing technique.
Todd
ID:	34652   Click image for larger version
Old 04-01-2007, 11:12 PM
Stepper Monkey is on a distinguished road
Artcam is a really easy way to take a B&W photo to a texture map, just change the contrast and brightness and you change the Z depth and scale. I know there are other programs that do the same thing but I'm not sure what all of them are.
I have a picture of an old stone wall done in Artcam that looks insanely realistic when dropped to a relief file. If you need some images modified into relief let me know.
Old 04-02-2007, 08:18 AM
thank you
Thank you very much for your input and ideas. I appreciate it! If you have any other ideas or sites in mind, fire them at me.
Old 04-02-2007, 12:28 PM
todd71's Avatar
http://www.vectric.com/ I think it will will do grayscale modeling. Check the vectric forum here on cnczone to be sure.
Old 04-02-2007, 01:36 PM
Hi and thanks. I have software to cut but I am looking for good stone patterns, artwork or dxf finished files to work with. I am simple trying to save some time. Thanks for the suggestion though!
Old 03-14-2008, 03:35 PM
bubthezombie6 is on a distinguished road
Go to http://www.marlinstudios.com/products/st4/st4.htm
They have a classic stone works texture CD that is used by 3d artists. Included is a matching "bump map" which is a grey scale image you should be able to use for relief carving.
Best of all, their stuff is seamless which means you can tile it as much as you like!
Last edited by bubthezombie6; 03-14-2008 at 03:36 PM. Reason: (changed link to direct link to product)
Stone machines???? anyone? Seabee Glass, Plastic and Stone 12 07-04-2011 04:33 PM
Stone Fab mess Perp Glass, Plastic and Stone 2 06-01-2007 10:23 PM
My DIY Stone Router DennisCNC Glass, Plastic and Stone 15 04-12-2007 09:38 AM
Bob-Cad V18 Stone Tazzer BobCad-Cam 2 09-19-2005 12:11 PM
CNC + stone Pruski Glass, Plastic and Stone 0 08-15-2004 02:21 PM
