01-29-2007, 10:52 PM
Originally Posted by bobyblue hi,
im new here and i am looking to do photo in halftone
engrave with rotating bit and then color fill and sand the excess, and i want to do it on stainless and aluminium,
the halftone would be about 60 to 65 d.p.i., i know how
to do in photoshop but how i convert into dot for cnc. Process is the same has preparing a photo for newspaper
but I want to do it with cnc, any help appreciate, tanks Bob |
VS3D can do this. You simply import the image scaling image brightness to surface height (lighter-higher, darker=lower). Then run a "Peck" (pogo-sitck) path using a V-bit to generate G-Code.
The resulting path will peck deeper where the image is darker.
And since a V-bit is used, the deeper it goes, the larger the diameter circle it makes. And when the holes are filled with black and the surface is polished, the darker parts of the image correspond to bigger black dots on the surface.
__________________ Daniel Carr - President,
Designs Computed, LLC |
