| Machine Created Art Discuss art created by machines here. |
Ok, I have a simple question about converting a pdf to dxf. When I convert a pdf in adobe illustrator to a dxf file then open it up into autocad the measurements are all wrong. What I am trying to do is take some plans in pdf form of a flat foam rc plane and convert to dxf to cut on my router. The plans were posted free on the net for us to download and print out and cut by hand. I can convert them in a tile form to print out on a standerd printer. Does someone know of a way to output the file from pdf to dxf without loosing its dims? Thanks Steve |
| Corel Draw seems to retain the dims OK, so far for me at least. Try posting a pdf here if not too big. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Strange, I can open them with Adobe reader, but Corel give a file corrupted message. Al.
Same here at my end using CorelDRAW X3.
__________________ HayTay Don't be the one that stands in the way of your success! |
| Aide PDF to DXF converter works well. There is a similar prodice put out by AnyDWG also that converts from PDF to DWG. Neither are free unfortunately.
__________________ If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do? Steven |
| Measure a known distance in AutoCAD and find out how much it's off, then select everything and scale it to the correct size.
#11
I tried it the other day myself and found that thigs came in scaled wrong. I wasnt going from pdf but directly from ai to dxf. Same sort of process though If you figure it out let me know and if I do I will be sure to post. |
